Up to 20% off select tools
Creating a Buttonhole Using a Sewing Machine
Views: 30K
View statistics:
Past 24 Hours:
3
Past 7 Days:
35
Past 30 Days:
173
All Time:
30,462
Comments: 2
2 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 20
20 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Patagonia
Patagonia and iFixit are celebrating the stories we wear by collaborating to provide guides for Patagonia's most popular apparel repairs.
Tools
Introduction
Go to step 1 ↓
Use this guide to create a buttonhole with your sewing machine. We’re using a Bernina 830, but the process should be similar for all sewing machines with a mechanical buttonhole dial. Since every sewing machine is different, refer to your sewing machine’s owner’s manual for specific information. In this guide we’re using contrasting thread for visibility. When it comes time for your actual project, you’ll want to use thread that matches the color of your fabric.
Return to the Patagonia Care & Repair homepage.
    1. Creating a Buttonhole Using a Sewing Machine, Creating a Buttonhole Using a Sewing Machine: step 1, image 1 of 2 Creating a Buttonhole Using a Sewing Machine, Creating a Buttonhole Using a Sewing Machine: step 1, image 2 of 2
      • Select your buttonhole foot. Buttonhole feet can vary in appearance, so check you manual.
      • Thread the buttonhole foot by sliding the thread through the diagonal slit into the center hole.
      Ask FixBot
    2. Creating a Buttonhole Using a Sewing Machine: step 2, image 1 of 2 Creating a Buttonhole Using a Sewing Machine: step 2, image 2 of 2
      • Mark where you would like the top and bottom of the buttonhole to be with tailor's chalk.
      • You can measure your button if you aren't sure.
      • Align the sewing machine at the upper left corner of the buttonhole.
      Ask FixBot
    3. Creating a Buttonhole Using a Sewing Machine: step 3, image 1 of 2 Creating a Buttonhole Using a Sewing Machine: step 3, image 2 of 2
      Ask FixBot
    4. Creating a Buttonhole Using a Sewing Machine: step 4, image 1 of 2 Creating a Buttonhole Using a Sewing Machine: step 4, image 2 of 2
      • Set your stitch length dial to nearly zero, this will create a satin stitch. The usual stitch length is around the 2.5.
      Ask FixBot
    5. Creating a Buttonhole Using a Sewing Machine: step 5, image 1 of 3 Creating a Buttonhole Using a Sewing Machine: step 5, image 2 of 3 Creating a Buttonhole Using a Sewing Machine: step 5, image 3 of 3
      • Set your button hole dial to one. If you have an electronic sewing machine, refer to your manual.
      • Every time you adjust this dial, your needle will move. That's okay; it's supposed to do that.
      • Start sewing. Sew to your second line.
      Ask FixBot
    6. Creating a Buttonhole Using a Sewing Machine: step 6, image 1 of 2 Creating a Buttonhole Using a Sewing Machine: step 6, image 2 of 2
      • Set your button hole dial to two.
      • Sew the bar tack at the bottom of the buttonhole.
      • Setting the button hole dial to two tells your sewing machine what to do, all you need to do is sew a few stitches to create the bar tack.
      Ask FixBot
    7. Creating a Buttonhole Using a Sewing Machine: step 7, image 1 of 2 Creating a Buttonhole Using a Sewing Machine: step 7, image 2 of 2
      • Set your buttonhole dial to three.
      • Sew up the second side of your buttonhole, stopping at your top mark.
      Ask FixBot
    8. Creating a Buttonhole Using a Sewing Machine: step 8, image 1 of 2 Creating a Buttonhole Using a Sewing Machine: step 8, image 2 of 2
      • Set your buttonhole dial to four.
      • Sew the top bar tack at the top of the buttonhole.
      Ask FixBot
    9. Creating a Buttonhole Using a Sewing Machine: step 9, image 1 of 2 Creating a Buttonhole Using a Sewing Machine: step 9, image 2 of 2
      • Set your buttonhole dial to five.
      • This setting backstitches to hold the thread in place. Sew a few more stitches, which will finish the buttonhole.
      Ask FixBot
    10. Creating a Buttonhole Using a Sewing Machine: step 10, image 1 of 2 Creating a Buttonhole Using a Sewing Machine: step 10, image 2 of 2
      • Clip the threads, freeing the fabric from the machine.
      • Clip any extra loose threads.
      Ask FixBot
    11. Creating a Buttonhole Using a Sewing Machine: step 11, image 1 of 2 Creating a Buttonhole Using a Sewing Machine: step 11, image 2 of 2
      • Use a hobby knife to cut open the buttonhole.
      • Be careful not to cut through the stitching, you only want to cut the fabric between the rows of stitching.
      Ask FixBot
Finish Line
7 other people completed this guide.
Author
with
Brittany McCrigler
91,191 Reputation
142 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
2 Guide Comments
I got up to position (!) 2 ok, then when I tried to go back up on position 3 it didn't work and just chewed up my fabric. Is it supposed to go backwards, or are you supposed to turn the fabric around? Did I do something wrong?
Holly - Reply Share
The same thing happened to me when I first tried this too, Holly.
I discovered that I was over-stitching position 2.
Now, I do a maximum 3 stitches only, before I go on to position 3 and everything works beautifully. I don’t have to turn the fabric around - position 3 stitches in reverse, and I finish off with a couple of stitches in position 2, to top off the button-hole.
I hope this helps!
Roszarie - Reply Share
Past 24 Hours: 3
Past 7 Days: 35
Past 30 Days: 173
All Time: 30,462
