Creality Ender 3 Pro Hotend Nozzle Replacement
  1. Creality Ender 3 Pro Hotend Nozzle Replacement, Hotend Nozzle: step 1, image 1 of 3 Creality Ender 3 Pro Hotend Nozzle Replacement, Hotend Nozzle: step 1, image 2 of 3 Creality Ender 3 Pro Hotend Nozzle Replacement, Hotend Nozzle: step 1, image 3 of 3
    • Press the knob to enter the Ender 3 Pro menu.
    • Turn the knob to navigate to the temperature menu.
    • Click on the nozzle setting found in the temperature menu.
    • Turn the knob to set the nozzle to 200 C.
    Ask FixBot
  2. Creality Ender 3 Pro Hotend Nozzle Replacement: step 2, image 1 of 1
    • Wait for the nozzle to heat up.
    • The nozzle will be at 200 C and should be handled with care to avoid burning yourself.
    Ask FixBot
  3. Creality Ender 3 Pro Hotend Nozzle Replacement: step 3, image 1 of 3 Creality Ender 3 Pro Hotend Nozzle Replacement: step 3, image 2 of 3 Creality Ender 3 Pro Hotend Nozzle Replacement: step 3, image 3 of 3
    • Depress the extruder spring using the handle.
    • Pull the filament from the extruder, while keeping constant pressure on the extruder spring.
    Ask FixBot
  4. Creality Ender 3 Pro Hotend Nozzle Replacement: step 4, image 1 of 3 Creality Ender 3 Pro Hotend Nozzle Replacement: step 4, image 2 of 3 Creality Ender 3 Pro Hotend Nozzle Replacement: step 4, image 3 of 3
    • Unscrew the two screws holding the fan shroud in place using the proper Allen key.
    Ask FixBot
  5. Creality Ender 3 Pro Hotend Nozzle Replacement: step 5, image 1 of 2 Creality Ender 3 Pro Hotend Nozzle Replacement: step 5, image 2 of 2
    • The hot end is still at 200 C, so be careful not to burn yourself!
    • Remove the silicon sock covering the hot end and nozzle.
    Ask FixBot
  6. Creality Ender 3 Pro Hotend Nozzle Replacement: step 6, image 1 of 2 Creality Ender 3 Pro Hotend Nozzle Replacement: step 6, image 2 of 2
    • Grab the hotend at the specified points using an adjustable wrench.
    • Be careful to avoid clamping the wires, ensuring the adjustable wrench only grabs the metal.
    Ask FixBot
  7. Creality Ender 3 Pro Hotend Nozzle Replacement: step 7, image 1 of 2 Creality Ender 3 Pro Hotend Nozzle Replacement: step 7, image 2 of 2
    • Remove the nozzle with a 7mm socket wrench.
    Ask FixBot
  8. Creality Ender 3 Pro Hotend Nozzle Replacement: step 8, image 1 of 3 Creality Ender 3 Pro Hotend Nozzle Replacement: step 8, image 2 of 3 Creality Ender 3 Pro Hotend Nozzle Replacement: step 8, image 3 of 3
    • Place the new nozzle within the 7mm socket wrench.
    • Grab the hotend using the adjustable wrench as seen in step 7.
    • Screw in the new nozzle again using the 7mm socket wrench.
    • Ensure the nozzle is hand tight as to not damage the hotend.
    Ask FixBot
  9. Creality Ender 3 Pro Hotend Nozzle Replacement: step 9, image 1 of 2 Creality Ender 3 Pro Hotend Nozzle Replacement: step 9, image 2 of 2
    • Reattach the fan shroud by screwing in the two screws.
    • Place the silicon sock back on the hot end, avoiding contact with the metal.
    Ask FixBot
  10. Creality Ender 3 Pro Hotend Nozzle Replacement: step 10, image 1 of 3 Creality Ender 3 Pro Hotend Nozzle Replacement: step 10, image 2 of 3 Creality Ender 3 Pro Hotend Nozzle Replacement: step 10, image 3 of 3
    • Navigate back to the temperature menu.
    • Set the nozzle temperature to 0 C, allowing it to cool down fully.
    Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 72
All Time: 1,132
