Crain Jamb Saw 775 2014 Blade Replacement
  1. Crain Jamb Saw 775 2014 Blade Replacement, Unfasten the blade: step 1, image 1 of 3 Crain Jamb Saw 775 2014 Blade Replacement, Unfasten the blade: step 1, image 2 of 3 Crain Jamb Saw 775 2014 Blade Replacement, Unfasten the blade: step 1, image 3 of 3
    • Unplug the power cord before you begin.
    • The saw blade is sharp, in order to prevent injury, you may want to wear protective gloves when handling it.
    • Depress the spindle lock button to prevent the blade from spinning when you unfasten it.
    • While depressing the spindle lock, use a 3/16 hex key to remove the socket set screw securing the blade in place.
    Ask FixBot
  2. Crain Jamb Saw 775 2014 Blade Replacement, Remove the blade: step 2, image 1 of 2 Crain Jamb Saw 775 2014 Blade Replacement, Remove the blade: step 2, image 2 of 2
    • Remove the blade.
    • When replacing with a new blade, ensure the two pegs on the face of the rotor mate with the holes in the blade.
    • Tighten the new blade with the socket set screw firmly before use. Ensure the spindle lock is pulled before turning the saw on.
    Ask FixBot
Tarun Thiruma
40,264 Reputation
134 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 23
All Time: 587
