Up to 20% off select tools
Craig Electronics CMP773 Volume/Power Control Button Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
49
All Time:
643
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If the volume/power control button on your Craig Electronics CMP773 tablet has quit working, this guide will demonstrate how to replace it with the correct tools. During this procedure, be especially careful not to let it fall out when snapping on and off the back cover.
    1. Craig Electronics CMP773 Volume/Power Control Button Replacement, Volume/Power Control Button: step 1, image 1 of 1
      • Remove the two 3.2 mm PH000 screws near the charging port.
      Ask FixBot
    2. Craig Electronics CMP773 Volume/Power Control Button Replacement: step 2, image 1 of 1
      • Pry the back cover from the device along bottom edge.
      Ask FixBot
    3. Craig Electronics CMP773 Volume/Power Control Button Replacement: step 3, image 1 of 1
      • Continue prying along each edge of the device until back cover is free.
      Ask FixBot
    4. Craig Electronics CMP773 Volume/Power Control Button Replacement: step 4, image 1 of 1
      • On the back cover, find the location where the volume/power button is held.
      • The volume/power button is not held securely after back is removed so it may fall out of place while removing the back cover from the device.
      Ask FixBot
    5. Craig Electronics CMP773 Volume/Power Control Button Replacement: step 5, image 1 of 2 Craig Electronics CMP773 Volume/Power Control Button Replacement: step 5, image 2 of 2
      • Remove the old button and replace it with the new one.
      Ask FixBot
Once the above steps have been successfully competed, power on the device. Enjoy your newly replaced volume/power control button.
Author
with
Jessie L Morris
171 Reputation
1 Guide authored
IUPUI, Team S1-G5, Harley Spring 2018 Member of IUPUI, Team S1-G5, Harley Spring 2018
IUPUI-HARLEY-S18S1G5
6 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 49
All Time: 643
