Up to 20% off select tools
Craig Electronics CMP773 Screen Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
56
All Time:
654
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 40 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
It is common for screens on tablets to scratch, crack, and break from use. Also, screens may malfunction or stop working for a number of reasons. This step by step guide will lead you through disassembling your Craig Electronics CMP773 in order to replace the screen.
    1. Craig Electronics CMP773 Screen Replacement, Screen: step 1, image 1 of 2 Craig Electronics CMP773 Screen Replacement, Screen: step 1, image 2 of 2
      • Remove two screws on the charging port side of the tablet using the Phillips #00 screwdriver.
      Ask FixBot
    2. Craig Electronics CMP773 Screen Replacement: step 2, image 1 of 3 Craig Electronics CMP773 Screen Replacement: step 2, image 2 of 3 Craig Electronics CMP773 Screen Replacement: step 2, image 3 of 3
      • Insert a plastic opening tool between the screen and the back of the tablet.
      • Insert another opening tool along the same side of the tablet and pry them in opposite directions until the casing pops.
      • Once roughly half of the case has been unlatched, it can be removed by hand.
      Ask FixBot
    3. Craig Electronics CMP773 Screen Replacement: step 3, image 1 of 2 Craig Electronics CMP773 Screen Replacement: step 3, image 2 of 2
      • Use the spudger to gently pry the camera from the casing.
      Ask FixBot
    4. Craig Electronics CMP773 Screen Replacement: step 4, image 1 of 2 Craig Electronics CMP773 Screen Replacement: step 4, image 2 of 2
      • Using your finger, remove the clamp that connects the screen power rib to the motherboard.
      • Using needle nose pliers, remove the ribbon.
      Ask FixBot
    5. Craig Electronics CMP773 Screen Replacement: step 5, image 1 of 3 Craig Electronics CMP773 Screen Replacement: step 5, image 2 of 3 Craig Electronics CMP773 Screen Replacement: step 5, image 3 of 3
      • Remove the second screen power connection from the motherboard using the same procedure as step 4.
      Ask FixBot
    6. Craig Electronics CMP773 Screen Replacement: step 6, image 1 of 3 Craig Electronics CMP773 Screen Replacement: step 6, image 2 of 3 Craig Electronics CMP773 Screen Replacement: step 6, image 3 of 3
      • Remove four screws from the motherboard using the Phillips #00 screwdriver.
      Ask FixBot
    7. Craig Electronics CMP773 Screen Replacement: step 7, image 1 of 2 Craig Electronics CMP773 Screen Replacement: step 7, image 2 of 2
      • Remove a single screw from the speaker using the Phillips #00 screwdriver.
      • Pry up on the locking tabs with the flat spudger.
      Ask FixBot
    8. Craig Electronics CMP773 Screen Replacement: step 8, image 1 of 1
      • Using needle nose pliers, remove the ground wire from the casing.
      Ask FixBot
    9. Craig Electronics CMP773 Screen Replacement: step 9, image 1 of 1
      • Using the plastic opening tool, remove the battery.
      Ask FixBot
    10. Craig Electronics CMP773 Screen Replacement: step 10, image 1 of 2 Craig Electronics CMP773 Screen Replacement: step 10, image 2 of 2
      • With all screws and components removed, gently remove the motherboard from the casing.
      Ask FixBot
    11. Craig Electronics CMP773 Screen Replacement: step 11, image 1 of 3 Craig Electronics CMP773 Screen Replacement: step 11, image 2 of 3 Craig Electronics CMP773 Screen Replacement: step 11, image 3 of 3
      • Insert the spudger in between the screen and case. Work your way around the outside of the screen.
      Ask FixBot
    12. Craig Electronics CMP773 Screen Replacement: step 12, image 1 of 3 Craig Electronics CMP773 Screen Replacement: step 12, image 2 of 3 Craig Electronics CMP773 Screen Replacement: step 12, image 3 of 3
      • Grasp the exposed screen corner and gently separate the screen from the housing.
      Ask FixBot
Author
with
Justin mersch
205 Reputation
1 Guide authored
IUPUI, Team S3-G4, Harley Fall 2019 Member of IUPUI, Team S3-G4, Harley Fall 2019
IUPUI-HARLEY-F19S3G4
4 Members
24 Guides authored
1 Guide Comment
What kind of battery does this device specifically use
Kris Miller - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 56
All Time: 654
