Craig Electronics CMP773 Front and Rear Camera Replacement
    1. Craig Electronics CMP773 Front and Rear Camera Replacement, Front and Rear Camera: step 1, image 1 of 2 Craig Electronics CMP773 Front and Rear Camera Replacement, Front and Rear Camera: step 1, image 2 of 2
      • Remove the two Phillips #00 screws from the bottom of the screen.
      Ask FixBot
    2. Craig Electronics CMP773 Front and Rear Camera Replacement: step 2, image 1 of 2 Craig Electronics CMP773 Front and Rear Camera Replacement: step 2, image 2 of 2
      • Insert a plastic opening tool underneath the screen.
      • Once the first tool is inserted, insert another opening tool along the same side of the tablet.
      • Pry them in opposite directions until the casing pops.
      Ask FixBot
    3. Craig Electronics CMP773 Front and Rear Camera Replacement: step 3, image 1 of 2 Craig Electronics CMP773 Front and Rear Camera Replacement: step 3, image 2 of 2
      • Move the opening tool along the edge of the tablet to continue popping the casing loose.
      • Once the casing is about half loose, remove it by hand.
      Ask FixBot
    4. Craig Electronics CMP773 Front and Rear Camera Replacement: step 4, image 1 of 2 Craig Electronics CMP773 Front and Rear Camera Replacement: step 4, image 2 of 2
      • Remove the tape from the power connection for the camera unit.
      • Unhinge the clamp on the camera power connection to expose the removable plug.
      Ask FixBot
    5. Craig Electronics CMP773 Front and Rear Camera Replacement: step 5, image 1 of 1
      • Gently remove the power ribbon from the connector.
      Ask FixBot
    6. Craig Electronics CMP773 Front and Rear Camera Replacement: step 6, image 1 of 2 Craig Electronics CMP773 Front and Rear Camera Replacement: step 6, image 2 of 2
      • Use the spudger to dislodge camera unit from the casing and remove it from the device.
      Ask FixBot
Luke VanLangevelde
133 Reputation
1 Guide authored
IUPUI, Team S3-G4, Harley Fall 2019 Member of IUPUI, Team S3-G4, Harley Fall 2019
IUPUI-HARLEY-F19S3G4
4 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 24
All Time: 342
