Craig Electronics CMP773 Battery Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
67
All Time:
651
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your Craig Electronics CMP773 battery is failing and needs replaced, this replacement guide will inform you of the steps to take when performing the replacement. Make sure you have the right tools before beginning this procedure.
Tools
    1. Craig Electronics CMP773 Battery Replacement, Battery: step 1, image 1 of 1
      • Remove the two 3.2 mm PH000 screws near the charging port.
      Ask FixBot
    2. Craig Electronics CMP773 Battery Replacement: step 2, image 1 of 1
      • Pry the back cover from the device along the bottom edge.
      Ask FixBot
    3. Craig Electronics CMP773 Battery Replacement: step 3, image 1 of 1
      • Continue prying along the edge of the device until the back cover is free.
      Ask FixBot
    4. Craig Electronics CMP773 Battery Replacement: step 4, image 1 of 1
      • Pry the battery free from the device using a plastic opening tool.
      Ask FixBot
    5. Craig Electronics CMP773 Battery Replacement: step 5, image 1 of 1
      • Desolder the faulty battery wires.
      Ask FixBot
    6. Craig Electronics CMP773 Battery Replacement: step 6, image 1 of 1
      • Solder the replacement battery wires to the circuit board.
      Ask FixBot
    7. Craig Electronics CMP773 Battery Replacement: step 7, image 1 of 1
      • Apply adhesive between the replacement battery and the device before installation.
      Ask FixBot
Once the above steps have been successfully competed, power on the device. Enjoy your newly replaced battery.
Jacob Hampton
145 Reputation
1 Guide authored
IUPUI, Team S1-G5, Harley Spring 2018 Member of IUPUI, Team S1-G5, Harley Spring 2018
IUPUI-HARLEY-S18S1G5
6 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 67
All Time: 651
