Craftsman Model 315.10721 Table Guard Replacement
  1. Craftsman Model 315.10721 Table Guard Replacement, Table Guard: step 1, image 1 of 1
    • Using a flathead screwdriver, remove the 1/2" flathead screw to allow the table guard to pivot.
  2. Craftsman Model 315.10721 Table Guard Replacement: step 2, image 1 of 1
    • Pivot the table guard from its upright position to an angle.
    • Using a Phillips #1 screwdriver, remove the 1" Phillips screw and the nut on the opposite side.
  3. Craftsman Model 315.10721 Table Guard Replacement: step 3, image 1 of 1
    • Using the Phillips #1 screwdriver, remove eight 1" Philips screws from the main case.
    • Carefully remove the main case to expose the inside of the saw.
  4. Craftsman Model 315.10721 Table Guard Replacement: step 4, image 1 of 1
    • Remove the old table guard by gently lifting it away from the main case.
    • Replace the old table guard with the new one by placing it in the same orientation as the one removed.
Riley Hilliker
557 Reputation
5 Guides authored
Cal Poly, Team 4-47, Amido Fall 2014 Member of Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
4 Members
5 Guides authored
2 Guide Comments
Where can I get a replacement table guard???
Roger Coyle - Reply Share
Where can I get a replacement table guard for this jig saw????????
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 26
All Time: 882
