Craftsman Model 315.10721 Blade Replacement
  1. Craftsman Model 315.10721 Blade Replacement, Blade: step 1, image 1 of 1
    • Be sure to unplug the saw before proceeding.
    • Using a flathead screwdriver, loosen the first 7/32" flathead screw on the saw blade clamp.
    • Rotate the saw blade clamp 90 degrees to the left and loosen the second 7/32" flathead screw
    • It is not necessary to completely remove the screws.
  2. Craftsman Model 315.10721 Blade Replacement: step 2, image 1 of 1
    • Carefully take the replacement blade and insert it into the saw blade clamp.
    • To secure the blade, retighten both 7/32" flathead screws on the saw blade clamp.
Finish Line
Riley Hilliker
557 Reputation
5 Guides authored
Cal Poly, Team 4-47, Amido Fall 2014 Member of Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
4 Members
5 Guides authored
2 Guide Comments
Where can I get replacement blades for this saw.
Edward - Reply Share
Where can I get replacement blades for this saw?
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 70
All Time: 4,576
