Cracked Grout Replacement
Views: 11K
View statistics:
Past 24 Hours:
10
Past 7 Days:
69
Past 30 Days:
334
All Time:
11,269
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 day
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Over time as a result of aging and other factors such as the original installment of the grout, climate, temperature, etc. your grout may begin to crack. With the right tools and direction, it is possible to repair these minor damages in the grout on your own. This guide will provide you with the instructions and tools to repairing these cracks in the grout. The tools listed in this guide are not common household items and can either be bought or rented. They are recommended to be used with protective eye wear and a mask to protect from dust and debris.
    1. Cracked Grout Replacement, Cracked Grout: step 1, image 1 of 2 Cracked Grout Replacement, Cracked Grout: step 1, image 2 of 2
      • Identify the crack you will be repairing.
      • Surround it with Painters Tape.
      Ask FixBot
    2. Cracked Grout Replacement: step 2, image 1 of 1
      • Wear protective eye wear and a mask to shield yourself from dust and debris.
      • Use caution when handling the concrete grinder. If handled improperly it can lead to an injury.
      • Use the concrete grinder to remove the grout surrounded with tape where the crack is located.
      Ask FixBot
    3. Cracked Grout Replacement: step 3, image 1 of 2 Cracked Grout Replacement: step 3, image 2 of 2
      • Go in with your handheld grout remover and scrape out the remaining grout between the tile until it is completely hollow.
      Ask FixBot
    4. Cracked Grout Replacement: step 4, image 1 of 2 Cracked Grout Replacement: step 4, image 2 of 2
      • Vacuum the dust and grout that was removed to reveal a clean and hollow space.
      Ask FixBot
    5. Cracked Grout Replacement: step 5, image 1 of 1
      • Color match your grout by using grout samples to get your desired color of grout.
      Ask FixBot
    6. Cracked Grout Replacement: step 6, image 1 of 3 Cracked Grout Replacement: step 6, image 2 of 3 Cracked Grout Replacement: step 6, image 3 of 3
      • Mix a scoop of grout and sealer to create a paste.
      Ask FixBot
    7. Cracked Grout Replacement: step 7, image 1 of 3 Cracked Grout Replacement: step 7, image 2 of 3 Cracked Grout Replacement: step 7, image 3 of 3
      • Take the rubber grout float and press the grout paste securely into the crack.
      Ask FixBot
    8. Cracked Grout Replacement: step 8, image 1 of 2 Cracked Grout Replacement: step 8, image 2 of 2
      • Take the grouting sponge and smooth out the grout evenly.
      • Let the grout sit and harden for twenty-four hours.
      Ask FixBot
    9. Cracked Grout Replacement: step 9, image 1 of 1
      • Your new grout is dry and ready for use.
      Ask FixBot
To repair any other cracks in grout, repeat these steps.
11 other people completed this guide.
1 Guide Comment
Excelente 👌
Superman07 - Reply Share
Past 24 Hours: 10
Past 7 Days: 69
Past 30 Days: 334
All Time: 11,269
