Cowin E7 Extension Arm Replacement
    1. Cowin E7 Extension Arm Replacement, Extension Arm: step 1, image 1 of 2 Cowin E7 Extension Arm Replacement, Extension Arm: step 1, image 2 of 2
      • Remove four screws from the extension arm using a TR Torx 10 screwdriver.
      Ask FixBot
    2. Cowin E7 Extension Arm Replacement: step 2, image 1 of 1
      • Pull up on the metal clamp.
      • Squeeze the pins on the top and bottom of the side you are trying to remove.
      • This will allow the extension bracket to easily slide out of the metal clamp.
      Ask FixBot
    3. Cowin E7 Extension Arm Replacement: step 3, image 1 of 1
      • Replace the damaged extension bracket with a new one.
      • To insert the new bracket, remember to squeeze the pins on the side that inserts into the metal clamp.
      Ask FixBot
Jacob Burrer
463 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 25
All Time: 1,440
