Up to 20% off select tools
Cosori TurboBlaze Control Panel Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
9
Past 7 Days:
67
Past 30 Days:
293
All Time:
2,064
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Is your Cosori TurboBlaze not properly heating your food? Is it not displaying the correct temperature on your control panel's display? If this is the case, then you can fix this issue with the replacement of your control panel's microprocessor inside the the main circuit board.
    1. Cosori TurboBlaze Control Panel Replacement, Control Panel: step 1, image 1 of 1
      • Use an iFixit opening tool to pry open the top lid of your air fryer.
      Ask FixBot
    2. Cosori TurboBlaze Control Panel Replacement: step 2, image 1 of 2 Cosori TurboBlaze Control Panel Replacement: step 2, image 2 of 2
      • Detach the white wire harness bundle from the main device.
      Ask FixBot
    3. Cosori TurboBlaze Control Panel Replacement: step 3, image 1 of 2 Cosori TurboBlaze Control Panel Replacement: step 3, image 2 of 2
      • Gently push each small translucent button inward.
      • This will help you detach the control panel from the bottom section of the lid.
      • Pull the white wire harness through.
      Ask FixBot
    4. Cosori TurboBlaze Control Panel Replacement: step 4, image 1 of 1
      • Remove the bottom panel of the lid.
      Ask FixBot
    5. Cosori TurboBlaze Control Panel Replacement: step 5, image 1 of 1
      • Remove four 1.2 mm screws from the control panel using a Phillips #1 screwdriver.
      Ask FixBot
    6. Cosori TurboBlaze Control Panel Replacement: step 6, image 1 of 2 Cosori TurboBlaze Control Panel Replacement: step 6, image 2 of 2
      • Flip the circuit board over to its backside to access the input controls.
      • If any input controls show signs of wear, cuts, or bends, then they must be replaced.
      Ask FixBot
Author
with
Ismael Martinez Castillo
647 Reputation
1 Guide authored
CSU Sacramento, Team 2-2, Laflen Fall 2024 Member of CSU Sacramento, Team 2-2, Laflen Fall 2024
CSUSAC-LAFLEN-F24S2G2
1 Member
12 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 67
Past 30 Days: 293
All Time: 2,064
