Cosori Pro II Motherboard Replacement
    1. Cosori Pro II Motherboard Replacement, Shell: step 1, image 1 of 1
      • Flip the device upside down and remove all of the Phillips #1 screws.
      Ask FixBot
    2. Cosori Pro II Motherboard Replacement: step 2, image 1 of 2 Cosori Pro II Motherboard Replacement: step 2, image 2 of 2
      • Use an opening tool to push on the retaining hooks to disengage them while prying slightly.
      • Remove the panel.
      Ask FixBot
    3. Cosori Pro II Motherboard Replacement: step 3, image 1 of 1
      • Use a Phillips #1 screwdriver to remove all four screws.
      • Lift off the bracket.
      • When lifting this off be careful to not unplug the screen.
      Ask FixBot
    4. Cosori Pro II Motherboard Replacement: step 4, image 1 of 2 Cosori Pro II Motherboard Replacement: step 4, image 2 of 2
      • Use a Phillips #0 screwdriver to remove all the screws connecting to the shell.
      • Dissemble the shell going up to separate the basket holder.
      Ask FixBot
    5. Cosori Pro II Motherboard Replacement: step 5, image 1 of 2 Cosori Pro II Motherboard Replacement: step 5, image 2 of 2
      • Use a Phillips #0 screwdriver and the 150 mm Flex Extension to unscrew the bottom plastic connecting to the basket holder.
      • Be careful to not apply too much force to the metal as it can cause it to warp it, and so it is easy rescrew the plastic piece in place.
      Ask FixBot
    6. Cosori Pro II Motherboard Replacement: step 6, image 1 of 2 Cosori Pro II Motherboard Replacement: step 6, image 2 of 2
      • Pull the bottom shell down pulling at the sides to get them over screw holes.
      Ask FixBot
    1. Cosori Pro II Motherboard Replacement, Motherboard: step 7, image 1 of 2 Cosori Pro II Motherboard Replacement, Motherboard: step 7, image 2 of 2
      • Depress the white clip and disconnect the screen connector.
      Ask FixBot
    2. Cosori Pro II Motherboard Replacement: step 8, image 1 of 2 Cosori Pro II Motherboard Replacement: step 8, image 2 of 2
      • Remove the plastic panel.
      Ask FixBot
    3. Cosori Pro II Motherboard Replacement: step 9, image 1 of 1
      • Remove the two screws with a Phillips #1 screwdriver.
      Ask FixBot
    4. Cosori Pro II Motherboard Replacement: step 10, image 1 of 3 Cosori Pro II Motherboard Replacement: step 10, image 2 of 3 Cosori Pro II Motherboard Replacement: step 10, image 3 of 3
      • Apply force simultaneously to the four hooks to release the mother board.
      • Using a prying tool pull out the springs on the mother board from their sockets.
      • Remove the motherboard.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 51
All Time: 697
