Corsair Void Pro RGB Volume Switch Replacement
  1. Corsair Void Pro RGB Volume Switch Replacement, Earcup: step 1, image 1 of 1
    • Carefully remove earmuff from headphones by getting a grip under the earmuff cushion and peeling up over the lip that keeps it in place.
    Ask FixBot
  2. Corsair Void Pro RGB Volume Switch Replacement: step 2, image 1 of 2 Corsair Void Pro RGB Volume Switch Replacement: step 2, image 2 of 2
    • Using the Phillips #0 screwdriver, unscrew the seven 6.4 mm screws holding the black speaker cover in place.
    • If you are disassembling the lefthand earfmuff, there will be eight 6.4 mm screws to remove.
    Ask FixBot
  3. Corsair Void Pro RGB Volume Switch Replacement: step 3, image 1 of 2 Corsair Void Pro RGB Volume Switch Replacement: step 3, image 2 of 2
    • Remove and set aside the black panel, taking care to keep the wires attached.
    • The panel should lift up without much force. If the panel does not budge, carefully use the iFixit plastic opening tool to dislodge the piece.
    Ask FixBot
  4. Corsair Void Pro RGB Volume Switch Replacement, Volume Switch: step 4, image 1 of 1
    • Using the Phillips #0 screwdriver, remove the three 6.4 mm screws on the black plastic panel with the grid of holes.
    Ask FixBot
  5. Corsair Void Pro RGB Volume Switch Replacement: step 5, image 1 of 1
    • Pull the volume switch out and remove it from the device.
    Ask FixBot
Gianna Nobili
854 Reputation
5 Guides authored
Cal Poly, Team S9-G13, Maness Spring 2019 Member of Cal Poly, Team S9-G13, Maness Spring 2019
CPSU-MANESS-S19S9G13
4 Members
14 Guides authored
1 Guide Comment
Heads up, some headsets have hot glue holding the wiring down below the speakers, and sometimes the hot glue will grab the speaker frame so its impossible to teardown the headset without damaging the wires, speaker or PCB board.
Found this out when my volume wheel was catching on something, so i decided to check it out. It was a glob of glue in the way of the wheel making it difficult to hit the switch to adjust the volume. Took me a little creative thinking to remove it with a plastic pointer/ scraper, and some fine tweezers, as the speaker panel was being held down by a large glob of glue.
USB Lynx - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 58
All Time: 3,772
