Corsair Scimitar Mouse Wheel Replacement
  1. Corsair Scimitar Mouse Wheel Replacement, Corsair Scimitar Mouse Wheel: step 1, image 1 of 2 Corsair Scimitar Mouse Wheel Replacement, Corsair Scimitar Mouse Wheel: step 1, image 2 of 2
    • Heat the mouse feet with a heat gun to loosen the adhesive.
    • Pry the mouse feet off of the mouse with the metal spudger.
    Ask FixBot
  2. Corsair Scimitar Mouse Wheel Replacement: step 2, image 1 of 2 Corsair Scimitar Mouse Wheel Replacement: step 2, image 2 of 2
    • Unscrew the four 8.9 mm bottom screws with a JIS #00 screwdriver.
    • Loosen the keyslider lock with a 2.5 mm hex screw driver.
    Ask FixBot
  3. Corsair Scimitar Mouse Wheel Replacement: step 3, image 1 of 3 Corsair Scimitar Mouse Wheel Replacement: step 3, image 2 of 3 Corsair Scimitar Mouse Wheel Replacement: step 3, image 3 of 3
    • Pry along the seam of the mouse body to separate the top and bottom halves.
    Ask FixBot
  4. Corsair Scimitar Mouse Wheel Replacement: step 4, image 1 of 3 Corsair Scimitar Mouse Wheel Replacement: step 4, image 2 of 3 Corsair Scimitar Mouse Wheel Replacement: step 4, image 3 of 3
    • Remove the top cover from the mouse.
    Ask FixBot
  5. Corsair Scimitar Mouse Wheel Replacement: step 5, image 1 of 3 Corsair Scimitar Mouse Wheel Replacement: step 5, image 2 of 3 Corsair Scimitar Mouse Wheel Replacement: step 5, image 3 of 3
    • Lift the locking mechanism on the auxiliary switch board ribbon cable connector with a plastic spudger.
    • Pull the ribbon cable gently to disconnect from the main board.
    Ask FixBot
  6. Corsair Scimitar Mouse Wheel Replacement: step 6, image 1 of 3 Corsair Scimitar Mouse Wheel Replacement: step 6, image 2 of 3 Corsair Scimitar Mouse Wheel Replacement: step 6, image 3 of 3
    • Lift the locking mechanism on the Key Slider assembly ribbon cable connector with a plastic spudger.
    • Pull the Key Slider assembly ribbon cable gently to disconnect it from the main board.
    Ask FixBot
  7. Corsair Scimitar Mouse Wheel Replacement: step 7, image 1 of 2 Corsair Scimitar Mouse Wheel Replacement: step 7, image 2 of 2
    • Pull the Keyslider ribbon cable up and out of the plastic post.
    Ask FixBot
  8. Corsair Scimitar Mouse Wheel Replacement: step 8, image 1 of 3 Corsair Scimitar Mouse Wheel Replacement: step 8, image 2 of 3 Corsair Scimitar Mouse Wheel Replacement: step 8, image 3 of 3
    • Use a JIS #0 screwdriver to remove the 6 mm screw from the key slider assembly.
    • Remove the key slider assembly from the body of the mouse.
    Ask FixBot
  9. Corsair Scimitar Mouse Wheel Replacement: step 9, image 1 of 3 Corsair Scimitar Mouse Wheel Replacement: step 9, image 2 of 3 Corsair Scimitar Mouse Wheel Replacement: step 9, image 3 of 3
    • Disconnect the data cable from the auxiliary switch board.
    Ask FixBot
  10. Corsair Scimitar Mouse Wheel Replacement: step 10, image 1 of 3 Corsair Scimitar Mouse Wheel Replacement: step 10, image 2 of 3 Corsair Scimitar Mouse Wheel Replacement: step 10, image 3 of 3
    • Use a JIS #0 screwdriver to remove the two 6 mm screws from the auxiliary switch board.
    • Remove the auxiliary switch board.
    Ask FixBot
  11. Corsair Scimitar Mouse Wheel Replacement: step 11, image 1 of 3 Corsair Scimitar Mouse Wheel Replacement: step 11, image 2 of 3 Corsair Scimitar Mouse Wheel Replacement: step 11, image 3 of 3
    • Use a JIS #0 screwdriver to remove the three 6 mm screws from the main board to separate it from the mouse body.
    Ask FixBot
  12. Corsair Scimitar Mouse Wheel Replacement: step 12, image 1 of 2 Corsair Scimitar Mouse Wheel Replacement: step 12, image 2 of 2
    • Disconnect the data cable from the main board.
    Ask FixBot
  13. Corsair Scimitar Mouse Wheel Replacement: step 13, image 1 of 2 Corsair Scimitar Mouse Wheel Replacement: step 13, image 2 of 2
    • Lift the main board off of the body of the mouse.
    Ask FixBot
  14. Corsair Scimitar Mouse Wheel Replacement: step 14, image 1 of 3 Corsair Scimitar Mouse Wheel Replacement: step 14, image 2 of 3 Corsair Scimitar Mouse Wheel Replacement: step 14, image 3 of 3
    • Push the scroll wheel gently away from the rotary encoder switch to remove it.
    • Check the rotary encoder hex hole to make sure it is clear of debris.
    Ask FixBot
  15. Corsair Scimitar Mouse Wheel Replacement: step 15, image 1 of 3 Corsair Scimitar Mouse Wheel Replacement: step 15, image 2 of 3 Corsair Scimitar Mouse Wheel Replacement: step 15, image 3 of 3
    • Remove the rubber ring from the scroll wheel.
    Ask FixBot
7 other people completed this guide.
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 57
Past 30 Days: 317
All Time: 12,470
