Up to 20% off select tools
Corsair Katar Disassembly
Views: 5.7K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
126
All Time:
5,706
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If you need to disassemble your Corsair Katar mouse, this guide will demonstrate how to take it apart.
    1. Corsair Katar Disassembly, Corsair Katar Disassembly: step 1, image 1 of 2 Corsair Katar Disassembly, Corsair Katar Disassembly: step 1, image 2 of 2
      • Unplug your mouse before starting.
      • Flip the mouse over so the bottom is facing up.
      Ask FixBot
    2. Corsair Katar Disassembly: step 2, image 1 of 1
      • Remove the three skates on the bottom of the mouse using the plastic opening tools.
      • Skates will be very sticky.
      Ask FixBot
    3. Corsair Katar Disassembly: step 3, image 1 of 2 Corsair Katar Disassembly: step 3, image 2 of 2
      • Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
      Ask FixBot
    4. Corsair Katar Disassembly: step 4, image 1 of 1
      • Detach the bottom of the mouse from the upper shell.
      • Remove the shell slowly so as not to damage the white DPI cable inside the mouse.
      • Use the plastic opening tool to detach the white DPI sensor cable from its port.
      • Alternatively, you can use your hand to remove the DPI sensor cable by wiggling it out of the port.
      Ask FixBot
3 other people completed this guide.
Author
with
Ryan Matesa
248 Reputation
1 Guide authored
UW Tacoma, Team S1-G3, Cardinal Summer 2018 Member of UW Tacoma, Team S1-G3, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G3
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 126
All Time: 5,706
