Up to 20% off select tools
Core Assembly Removal
Views: 1.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
10
Past 30 Days:
84
All Time:
1,860
Comments: 8
8 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to remove the core assembly in the Samsung Galaxy Watch4 Classic.
    1. Core Assembly Removal, Power down your watch: step 1, image 1 of 1
      • Before starting repairs, take your watch off the charger and power it down.
      • Remove the watch band.
      Ask FixBot
    2. Core Assembly Removal, Unscrew the back cover: step 2, image 1 of 1
      • Use a Tri-point Y00 screwdriver to remove the four 4.0 mm-long screws securing the back cover.
      Ask FixBot
    3. Core Assembly Removal, Pry open the back cover: step 3, image 1 of 2 Core Assembly Removal, Pry open the back cover: step 3, image 2 of 2
      • Insert an opening tool into the seam between the back cover and the metal housing.
      • Twist the opening tool to create a gap.
      • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
      Ask FixBot
    4. Core Assembly Removal, Disconnect the sensor flex cable: step 4, image 1 of 2 Core Assembly Removal, Disconnect the sensor flex cable: step 4, image 2 of 2
      • Lay the watch face down.
      • Carefully swing open the back cover by folding it to the opposite site of the created gap.
      • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
      Ask FixBot
    5. Core Assembly Removal, Remove the back cover: step 5, image 1 of 1
      • Remove the back cover.
      • Make sure the rubber gasket is undamaged. If damaged, replace it with a new one during reassembly to maintain proper water resistance.
      Ask FixBot
    1. Core Assembly Removal, Disconnect the hall sensor flex cable: step 6, image 1 of 2 Core Assembly Removal, Disconnect the hall sensor flex cable: step 6, image 2 of 2
      • Use the pointed end of a spudger to disconnect the hall sensor flex cable.
      Ask FixBot
    2. Core Assembly Removal, Disconnect the display flex cable: step 7, image 1 of 2 Core Assembly Removal, Disconnect the display flex cable: step 7, image 2 of 2
      • Use a spudger to disconnect the display flex cable.
      Ask FixBot
    3. Core Assembly Removal, Disconnect the side buttons: step 8, image 1 of 2 Core Assembly Removal, Disconnect the side buttons: step 8, image 2 of 2
      • Use a spudger to disconnect the crown button flex cable.
      Ask FixBot
    4. Core Assembly Removal, Unscrew the motherboard: step 9, image 1 of 1
      • Use a Phillips screwdriver to remove the 4.4 mm-long screw securing the motherboard.
      Ask FixBot
    5. Core Assembly Removal, Remove the motherboard: step 10, image 1 of 3 Core Assembly Removal, Remove the motherboard: step 10, image 2 of 3 Core Assembly Removal, Remove the motherboard: step 10, image 3 of 3
      • Use your fingers to lift the motherboard out from the watch assembly towards the bottom of the watch.
      • During reassembly, make sure none of the flex cables become trapped underneath the motherbaord.
      Ask FixBot
    1. Core Assembly Removal, Lift the core assembly: step 11, image 1 of 3 Core Assembly Removal, Lift the core assembly: step 11, image 2 of 3 Core Assembly Removal, Lift the core assembly: step 11, image 3 of 3
      • Place the corner of the flat end of a spudger in the small opening of the barometric sensor, on the opposite side of the display connector.
      • Twist and tilt the spudger to lever the core assembly out of the metal housing.
      Ask FixBot
    2. Core Assembly Removal, Release the core assembly: step 12, image 1 of 2 Core Assembly Removal, Release the core assembly: step 12, image 2 of 2
      • Thread the display flex cable through the opening in the core assembly.
      Ask FixBot
    3. Core Assembly Removal, Remove the core assembly: step 13, image 1 of 1
      • Remove the core assembly.
      Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
2 other people completed this guide.
Author
with
Adriana Zwink
69,920 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 84
All Time: 1,860
