Up to 20% off select tools
Core Assembly Removal
Views: 2.3K
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
74
All Time:
2,344
Comments: 8
8 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to remove the core assembly in your Samsung Galaxy Watch Active.
    1. Core Assembly Removal, Turn off the watch: step 1, image 1 of 2 Core Assembly Removal, Turn off the watch: step 1, image 2 of 2
      • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
      • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
      Ask FixBot
    2. Core Assembly Removal, Remove the rear screws: step 2, image 1 of 1
      • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
      Ask FixBot
    3. Core Assembly Removal, Separate the back cover from the housing: step 3, image 1 of 3 Core Assembly Removal, Separate the back cover from the housing: step 3, image 2 of 3 Core Assembly Removal, Separate the back cover from the housing: step 3, image 3 of 3
      • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
      • Push the tip of the opening tool into the gap to separate the back cover from the housing.
      • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
      Ask FixBot
    4. Core Assembly Removal, Disconnect the sensor array: step 4, image 1 of 2 Core Assembly Removal, Disconnect the sensor array: step 4, image 2 of 2
      • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
      • Use a spudger to disconnect the sensor array from the motherboard.
      Ask FixBot
    5. Core Assembly Removal, Remove the back cover: step 5, image 1 of 1
      • Remove the back cover.
      Ask FixBot
    1. Core Assembly Removal, Disconnect the display and the mic array: step 6, image 1 of 3 Core Assembly Removal, Disconnect the display and the mic array: step 6, image 2 of 3 Core Assembly Removal, Disconnect the display and the mic array: step 6, image 3 of 3
      • Use a spudger to disconnect the display assembly and the microphone and pressure sensor array.
      Ask FixBot
    2. Core Assembly Removal, Undo the mic tape: step 7, image 1 of 3 Core Assembly Removal, Undo the mic tape: step 7, image 2 of 3 Core Assembly Removal, Undo the mic tape: step 7, image 3 of 3
      • Use an opening pick to peel back the thin tape belonging to the microphone array.
      • When re-assembling make sure this tape properly sticks to the motherboard by pressing it down with the flat end of a spudger.
      Ask FixBot
    3. Core Assembly Removal, Lift the core assembly: step 8, image 1 of 2 Core Assembly Removal, Lift the core assembly: step 8, image 2 of 2
      • Insert an opening pick at the bottom right between the motherboard and the frame to lift up the core assembly.
      Ask FixBot
    4. Core Assembly Removal, Remove the core assembly: step 9, image 1 of 3 Core Assembly Removal, Remove the core assembly: step 9, image 2 of 3 Core Assembly Removal, Remove the core assembly: step 9, image 3 of 3
      • Lift out and remove the core assembly.
      Ask FixBot
3 other people completed this guide.
Tobias Isakeit
136,836 Reputation
189 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 74
All Time: 2,344
