Up to 20% off select tools
Core Assembly Removal
Views: 1.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
80
All Time:
1,895
Comments: 6
5 comments on steps, 1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to remove the core assembly in your TicWatch Pro.
    1. Core Assembly Removal, Unfasten the screws: step 1, image 1 of 1
      • Before starting repairs, take your watch off the charger and power it down.
      • Remove the four 3.9 mm-long Torx T3 screws.
      • Depending on the condition of your driver, a Torx T4 bit may fit better.
      • Don't try to detach the back cover yet. It is still connected to the watch assembly.
      Ask FixBot
    2. Core Assembly Removal, Open the watch: step 2, image 1 of 2 Core Assembly Removal, Open the watch: step 2, image 2 of 2
      • Be careful not to strain the sensor flex cable during this procedure.
      • Carefully lift the back cover by the watch crown edge and swing it open to an upward position.
      Ask FixBot
    3. Core Assembly Removal, Disconnect the sensor cable: step 3, image 1 of 2 Core Assembly Removal, Disconnect the sensor cable: step 3, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the sensor flex cable.
      Ask FixBot
    4. Core Assembly Removal, Remove the back cover: step 4, image 1 of 1
      • Remove the back cover.
      Ask FixBot
    1. Core Assembly Removal, Core Assembly Removal: step 5, image 1 of 1
      • Remove the three 3.7 mm-long Phillips #00 screws.
      Ask FixBot
    2. Core Assembly Removal: step 6, image 1 of 3 Core Assembly Removal: step 6, image 2 of 3 Core Assembly Removal: step 6, image 3 of 3
      • Insert the flat end of a spudger into the notch at the upper end of the white plastic frame.
      • Use your spudger as a lever and pry up the core assembly.
      • Don't try to remove the core assembly all the way yet—it is still connected to the watch body.
      Ask FixBot
    3. Core Assembly Removal: step 7, image 1 of 2 Core Assembly Removal: step 7, image 2 of 2
      • Carefully lift the loose edge of the core assembly up and swing it to a 100-degree angle.
      • Be careful not to strain the display and sensor flex cables during this procedure.
      Ask FixBot
    4. Core Assembly Removal: step 8, image 1 of 2 Core Assembly Removal: step 8, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the core assembly.
      Ask FixBot
    5. Core Assembly Removal: step 9, image 1 of 2 Core Assembly Removal: step 9, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the display flex cable from the core assembly.
      Ask FixBot
    6. Core Assembly Removal: step 10, image 1 of 1
      • Remove the core assembly.
      Ask FixBot
Repair didn’t go as planned? Check out our Answers community for help.
4 other people completed this guide.
Author
with
Dominik Schnabelrauch
268,200 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
1 Guide Comment
Hello... in the event that you have submerged the smartwatch in salt water and it does not work, is there a solution?
luciano.alonso84@gmail.com - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 80
All Time: 1,895
