Up to 20% off select tools
Cordless Drill disassembly
Views: 4.9K
View statistics:
Past 24 Hours:
10
Past 7 Days:
41
Past 30 Days:
218
All Time:
4,899
Comments: 1
1 comment on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
A drill is an important tool required in every home as it is needed for removing fastened screws and for drilling holes. No matter if it is a portable or core drill, it is better to use the following repair tips to ensure your drill is always working
      • Open the drill to analyze its internal pieces and find out which pieces have to be repaired or replaced.
      Ask FixBot
      • Lay a towel on your work place, remove all the screws holding the drill together and place them on the towel. This ensures they don’t roll away. Next open the casing to expose the drill’s internal components.
      Ask FixBot
      • Remove the screws at the bottom of the drill’s mechanical components and gently pull out the components from the drill’s exterior casing.
      Ask FixBot
      • Check the trigger component under the drill motor as this part may malfunction with frequent use. Replace any damage you see to the trigger assembly.
      Ask FixBot
      • Next check the plastic wheel fans for damage which also may break into pieces with frequent use. Slide out these pieces from the portable drill’s assembly to replace them.
      Ask FixBot
      • After inspecting the interior components, reassemble the portable drill by placing all pieces in its original places and closing the exterior casing by refastening all removed screws.
      Ask FixBot
      • Switch on the drill to test it by placing a multimeter's two prongs to the portable drill’s electrical wiring. Record the findings and compare them with the ohm and voltage information on the owner’s manual or in the back plate.
      Ask FixBot
      • If the multimeter's reading and the listed voltage do not coincide, it means that the drill has an electrical wiring problem that has to be repaired by a qualified technician.
      Ask FixBot
5 other people completed this guide.
Author
with
Mark
255 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 41
Past 30 Days: 218
All Time: 4,899
