Up to 20% off select tools
Cord Lock Replacement
Views: 6.3K
View statistics:
Past 24 Hours:
20
Past 7 Days:
138
Past 30 Days:
556
All Time:
6,278
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Patagonia
Patagonia and iFixit are celebrating the stories we wear by collaborating to provide guides for Patagonia's most popular apparel repairs.
Parts
Tools
Introduction
Go to step 1 ↓
A cord lock is a small mechanism, often made of plastic, that is attached to a drawcord to secure it in place, allowing for easy adjustment of tightness and looseness. When the cord lock is damaged or missing, the drawcord becomes non-adjustable.
This guide demonstrates how to replace a cord lock without the need for sewing. To ensure this solution is applicable, confirm that the cord lock is not sewn in place and that at least one end of the drawcord is not sewn into the item, allowing for the cord lock to be removed without undoing any stitches.
Read through the entire guide before starting the repair, and gather the necessary tools and materials. While Patagonia-specific materials are ideal, they are not required. Patagonia replacement parts can be obtained by calling or messaging Patagonia Customer Service.
Alternatively, Patagonia products can be taken to a local retail store for repair evaluation or sent in to Patagonia through their mail-in repair service.
Let's get fixing!
WARNING! Small Parts. Patagonia does not recommend conducting these repairs on garments intended for children age 3 or under. Instead, we recommend return of the product for professional repair services.
Related tutorial: Elastic Drawcord Replacement
Return to the Patagonia Care & Repair homepage.
    1. Cord Lock Replacement, Assess the damage: step 1, image 1 of 3 Cord Lock Replacement, Assess the damage: step 1, image 2 of 3 Cord Lock Replacement, Assess the damage: step 1, image 3 of 3
      • Locate the damaged cord lock and take note of:
      • Type - The style of cord lock and how many holes it has
      • Drawcord - How the drawcord threads through the cord lock and how the drawcord ends (end cap, knot, stitching)
      • Other Pieces - If the cord lock and drawcord are used in conjunction with any other pieces such as a rubber pull tab or plastic disc
      • If the cord lock is missing and it isn't clear how it was originally placed, see Step 7 for tips.
      • Check the other cord locks along that same drawcord. It's best practice to replace all damaged cord locks at the same time.
      Ask FixBot
    2. Cord Lock Replacement, Release the drawcord: step 2, image 1 of 3 Cord Lock Replacement, Release the drawcord: step 2, image 2 of 3 Cord Lock Replacement, Release the drawcord: step 2, image 3 of 3
      • On the end of the drawcord closest to the damaged cord lock, use flush cutters to pry off the tip of the end cap.
      • Wear safety glasses.
      • Save this piece.
      • Pull the drawcord end out of the end cap and untie the knot.
      • Remove the base of the end cap and any plastic discs (if present).
      • Save these pieces.
      Ask FixBot
    3. Cord Lock Replacement, Replace the cord lock: step 3, image 1 of 3 Cord Lock Replacement, Replace the cord lock: step 3, image 2 of 3 Cord Lock Replacement, Replace the cord lock: step 3, image 3 of 3
      • Unthread the drawcord until it passes entirely through the damaged cord lock.
      • Remember this pathway so it can be restored in Step 4.
      • Responsibly discard the damaged cord lock.
      • Thread the drawcord through a new cord lock by pushing the cord lock mechanism (reference image #2) and inserting the drawcord through the opening.
      • Double check that the positioning of the new cord lock on the drawcord matches the original.
      Ask FixBot
    4. Cord Lock Replacement, Rethread the drawcord: step 4, image 1 of 3 Cord Lock Replacement, Rethread the drawcord: step 4, image 2 of 3 Cord Lock Replacement, Rethread the drawcord: step 4, image 3 of 3
      • Rethread the drawcord so it's restored to its original position.
      • Patagonia Repair Tech Tip: There are a variety of threaders that can aid with this step. These photos show a latch hook, which has a small hook for navigating small but short spaces. Alternatively, use a plastic drawstring threader, a bodkin, or a small safety pin.
      Ask FixBot
    5. Cord Lock Replacement, Restore the drawcord: step 5, image 1 of 3 Cord Lock Replacement, Restore the drawcord: step 5, image 2 of 3 Cord Lock Replacement, Restore the drawcord: step 5, image 3 of 3
      • Thread the end cap base back on to the drawcord.
      • Tie a knot at the end of the drawcord, then pull it tight and snip or singe any excess.
      • Pull the drawcord so the knot rests inside the end cap base.
      • Check that the knot does not pull through the end cap.
      • Replace the end cap tip by snapping it into place.
      Ask FixBot
    6. Cord Lock Replacement, Functionality test and quality control: step 6, image 1 of 3 Cord Lock Replacement, Functionality test and quality control: step 6, image 2 of 3 Cord Lock Replacement, Functionality test and quality control: step 6, image 3 of 3
      • Pull on the exposed drawcord to make sure it's secure.
      • Tighten and loosen the drawcord using the new cord lock to ensure it's functioning correctly.
      Ask FixBot
    7. Cord Lock Replacement, Troubleshooting: step 7, image 1 of 3 Cord Lock Replacement, Troubleshooting: step 7, image 2 of 3 Cord Lock Replacement, Troubleshooting: step 7, image 3 of 3
      • VARIATONS: There are many varieties of cord locks on the vast array of Patagonia items. The techniques and steps outlined in this tutorial can be rearranged or modified to fit the circumstances.
      • MISSING CORD LOCK: If the cord lock is missing entirely, use the remaining cord locks and grosgrain loops as context clues. Alternatively, try to find photos of the item on Patagonia.com, WornWear.com, or Google image search.
      Ask FixBot
Finish Line
Author
with
Clara Redwood
2,574 Reputation
19 Guides authored
Patagonia Member of Patagonia
Community
9 Members
384 Guides authored
0 Guide Comments
Past 24 Hours: 20
Past 7 Days: 138
Past 30 Days: 556
All Time: 6,278
