Copic Marker Nib Replacement
Views: 3.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
125
All Time:
3,660
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 8 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Tired of buying new Copic Markers? Wish you could just simply replace the nib? Well, this is the guide for you!
After using a Copic Marker for a long period of time and the nib begins to curl and fray, it is time to replace it. The ink also should be refilled simultaneously at this point as it is running low. The only tools needed to complete this guide are some paper towels and a pair of tweezer!
    1. Copic Marker Nib Replacement, Copic Marker Nib: step 1, image 1 of 1
      • Place a few paper towels on the surface of your workspace to protect it from ink spills.
      Ask FixBot
    2. Copic Marker Nib Replacement: step 2, image 1 of 1
      • Remove the cap from the marker to expose the nib.
      Ask FixBot
    3. Copic Marker Nib Replacement: step 3, image 1 of 3 Copic Marker Nib Replacement: step 3, image 2 of 3 Copic Marker Nib Replacement: step 3, image 3 of 3
      • Gently tug out the thicker part of the nib with the tweezer.
      Ask FixBot
    4. Copic Marker Nib Replacement: step 4, image 1 of 2 Copic Marker Nib Replacement: step 4, image 2 of 2
      • Remove the cap of the ink bottle and tilt the container to begin filling the marker.
      • Avoid forcibly squeezing the ink bottle.
      • Slowly fill the pen until it is approximately 3/4ths of the way full.
      Ask FixBot
    5. Copic Marker Nib Replacement: step 5, image 1 of 3 Copic Marker Nib Replacement: step 5, image 2 of 3 Copic Marker Nib Replacement: step 5, image 3 of 3
      • Insert the flat side of the new nib facing the opening of the marker until it snaps into place.
      • Set the marker down after replacing new nib.
      Ask FixBot
    6. Copic Marker Nib Replacement: step 6, image 1 of 3 Copic Marker Nib Replacement: step 6, image 2 of 3 Copic Marker Nib Replacement: step 6, image 3 of 3
      • Wait 3 minutes for the color to spread through the nib until it is no longer white.
      • Press on the middle of the marker 3 times to insure ink is spread throughout.
      • Repeat steps 3 - 5 if the amount of ink is insufficient.
      Ask FixBot
Finish Line
2 other people completed this guide.
Iris Lin
149 Reputation
1 Guide authored
UC Davis, Team S1-G5, Coad Spring 2017 Member of UC Davis, Team S1-G5, Coad Spring 2017
UCD-COAD-S17S1G5
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 125
All Time: 3,660
