Coolpix S01 Screen Cover Replacement
    1. Coolpix S01 Screen Cover Replacement, Screen Cover: step 1, image 1 of 3 Coolpix S01 Screen Cover Replacement, Screen Cover: step 1, image 2 of 3 Coolpix S01 Screen Cover Replacement, Screen Cover: step 1, image 3 of 3
      • First make sure the camera is powered off.
      • Use the Hex and PH000 tool to remove the 2 mm screw from the left side of the camera.
      Ask FixBot
    2. Coolpix S01 Screen Cover Replacement: step 2, image 1 of 3 Coolpix S01 Screen Cover Replacement: step 2, image 2 of 3 Coolpix S01 Screen Cover Replacement: step 2, image 3 of 3
      • Next, remove the 2 mm screw from the right side of the camera
      • Remove the 3mm screw from the bottom of the camera.
      • Once you have the 2mm and 3mm screws out, gently pull the sides up with the smallest plastic opening tool. This will reveal the inside of the camera.
      • Be sure to remove the battery before continuing your repair.
      Ask FixBot
    3. Coolpix S01 Screen Cover Replacement: step 3, image 1 of 3 Coolpix S01 Screen Cover Replacement: step 3, image 2 of 3 Coolpix S01 Screen Cover Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • With the screen facing outward, locate the orange ribbon cable from the motherboard.
      • With the straight tweezers, gently pull out the orange ribbon cable from the motherboard.
      Ask FixBot
    4. Coolpix S01 Screen Cover Replacement: step 4, image 1 of 3 Coolpix S01 Screen Cover Replacement: step 4, image 2 of 3 Coolpix S01 Screen Cover Replacement: step 4, image 3 of 3
      • With the lens facing down and the bottom of the camera facing away from you, lift up the right edge of the LCD screen.
      • Use the plastic tool to gently lift the screen out from the upper left corner until the seal is broken.
      Ask FixBot
angelica fitzgerald
216 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 31
All Time: 1,024
