Coolpix S01 Battery Replacement
    1. Coolpix S01 Battery Replacement, Battery: step 1, image 1 of 3 Coolpix S01 Battery Replacement, Battery: step 1, image 2 of 3 Coolpix S01 Battery Replacement, Battery: step 1, image 3 of 3
      • Before starting, make sure the camera is powered off.
      • Take the Hex and PH000 bit to remove a 2mm screw from the left side of the camera.
      • Next, remove the 2mm screw from the right side.
      • Lastly, remove the 3mm screw from the bottom of the camera.
      Ask FixBot
    2. Coolpix S01 Battery Replacement: step 2, image 1 of 3 Coolpix S01 Battery Replacement: step 2, image 2 of 3 Coolpix S01 Battery Replacement: step 2, image 3 of 3
      • Once the two 2mm screws and the 3 mm screw have been removed, use the smallest plastic opening tool and pull up on the sides to reveal the inside of the camera.
      • Next, use the same small plastic opening tool and gently pull out the battery.
      • To reassemble, follow the steps in reverse order.
      Ask FixBot
5 other people completed this guide.
Becca Hall
221 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 23
Past 30 Days: 108
All Time: 5,465
