Up to 20% off select tools
Coolpad Defiant Daughterboard Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
11
Past 30 Days:
56
All Time:
1,064
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the daughterboard in your phone.
    1. Coolpad Defiant Daughterboard Replacement, Back Cover: step 1, image 1 of 2 Coolpad Defiant Daughterboard Replacement, Back Cover: step 1, image 2 of 2
      • Turn the phone with the back cover facing towards you.
      • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
      • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
      Ask FixBot
    2. Coolpad Defiant Daughterboard Replacement: step 2, image 1 of 1
      • Remove the back cover from your device.
      Ask FixBot
    1. Coolpad Defiant Daughterboard Replacement, Battery: step 3, image 1 of 1
      • Find the gap on the bottom of the battery.
      • With a tool or with your hands, pull the battery upward and set it aside safely.
      • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
      • Be careful with old or damaged batteries and dispose of it appropriately
      Ask FixBot
    1. Coolpad Defiant Daughterboard Replacement, Daughterboard: step 4, image 1 of 2 Coolpad Defiant Daughterboard Replacement, Daughterboard: step 4, image 2 of 2
      • Remove all fifteen screws using the Phillips #000 screwdriver.
      • Remove the back panel after all screws are removed.
      Ask FixBot
    2. Coolpad Defiant Daughterboard Replacement: step 5, image 1 of 3 Coolpad Defiant Daughterboard Replacement: step 5, image 2 of 3 Coolpad Defiant Daughterboard Replacement: step 5, image 3 of 3
      • Disconnect the metal cable using the plastic spudger.
      • The remove the glued down speaker from the backing.
      • Disconnect the little black wire from lower logic board.
      Ask FixBot
    3. Coolpad Defiant Daughterboard Replacement: step 6, image 1 of 1
      • Using the plastic spudger remove the lower logic board because the only thing that is holding it down is glue.
      Ask FixBot
Author
with
Elijah Gastin
100 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 56
All Time: 1,064
