Cooler Master Laptop Fan Replacement
    1. Cooler Master Laptop Fan Replacement, Fan: step 1, image 1 of 1
      • Set your laptop cooler on the table and make sure it is not plugged into a laptop or powered on.
      • Never try to open the cooler while plugged in.
      Ask FixBot
    2. Cooler Master Laptop Fan Replacement: step 2, image 1 of 1
      • Flip the Device over and find ten folded metal slots holding the metal cover onto the base.
      Ask FixBot
    3. Cooler Master Laptop Fan Replacement: step 3, image 1 of 3 Cooler Master Laptop Fan Replacement: step 3, image 2 of 3 Cooler Master Laptop Fan Replacement: step 3, image 3 of 3
      • Bend each metal flap straight up with the pliers to allow the metal cover to slide off.
      Ask FixBot
    4. Cooler Master Laptop Fan Replacement: step 4, image 1 of 2 Cooler Master Laptop Fan Replacement: step 4, image 2 of 2
      • Remove the cover and expose the inside of the Cooler.
      Ask FixBot
    5. Cooler Master Laptop Fan Replacement: step 5, image 1 of 2 Cooler Master Laptop Fan Replacement: step 5, image 2 of 2
      • Unplug the power cable to the fan.
      • Make sure not to apply too much force and disconnect the wires to the device.
      Ask FixBot
    6. Cooler Master Laptop Fan Replacement: step 6, image 1 of 2 Cooler Master Laptop Fan Replacement: step 6, image 2 of 2
      • On the bottom of the base locate the screw holes under the sticker on the base.
      • Unscrew the three fan screws.
      Ask FixBot
    7. Cooler Master Laptop Fan Replacement: step 7, image 1 of 1
      • Once all the pieces are taken apart, set aside the old fan and prep the new one for installation.
      Ask FixBot
    8. Cooler Master Laptop Fan Replacement: step 8, image 1 of 1
      • Apply a small amount of thermal compound to the base where the fan sets.
      • Make sure to apply thermal compound to keep the fan from overheating and damaging the base.
      Ask FixBot
    9. Cooler Master Laptop Fan Replacement: step 9, image 1 of 2 Cooler Master Laptop Fan Replacement: step 9, image 2 of 2
      • Connect power cable for the fan and place the cables back in their slots.
      Ask FixBot
    10. Cooler Master Laptop Fan Replacement: step 10, image 1 of 2 Cooler Master Laptop Fan Replacement: step 10, image 2 of 2
      • Screw fan back onto base.
      Ask FixBot
    11. Cooler Master Laptop Fan Replacement: step 11, image 1 of 1
      • Place cover back on base.
      Ask FixBot
    12. Cooler Master Laptop Fan Replacement: step 12, image 1 of 1
      • Fold all metal flaps back to hold cover on base.
      Ask FixBot
    13. Cooler Master Laptop Fan Replacement: step 13, image 1 of 1
      • Flip it over and it's finished.
      Ask FixBot
Plug in the USB to insure proper working condition. And the cooling pad fan replacement is done.
3 other people completed this guide.
2 Guide Comments
Hi there,
I’ve got a Targus Lap Chill Matt (Laptop Cooling Pad 15 - 17" Laptops) but the USB port had worn out and require a new replacement. Does anyone have any examples on how to replace the UBS port from a Laptop Cooler Pad?
Thanks!
rolly - Reply Share
Hi,
Just wanted to say huge thanks to you for this guideline! I have a Cooler Master Notepal L1 and the fan kept making noises. But now it works totally fine after I was able to open the cover.
Thanks again!
//Parisa
Parisa - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 89
All Time: 7,866
