Up to 20% off select tools
Controller Plate/Buttons Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
125
All Time:
2,243
Comments: 3
3 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Controller Plate/Buttons Replacement, Controller Plate/Buttons Replacement: step 1, image 1 of 1
      • Follow the Prerequisite Guide on how to Replace the Battery to prepare the phone for disassemble. Remove, but do not replace the battery.
      Ask FixBot
    2. Controller Plate/Buttons Replacement: step 2, image 1 of 1
      • Remove all screws on the plastic case with a T6 Torx T-4 screwdriver, as shown.
      • Blue Circle: T6 Torx, Length 5mm
      • Red Circle: T6 Torx, Length 4mm
      • The screen and other parts are now loose and can easily fall off.
      Ask FixBot
    3. Controller Plate/Buttons Replacement: step 3, image 1 of 1
      • Separate the back cover from the phone. A plastic removal tool can be used here.
      Ask FixBot
    4. Controller Plate/Buttons Replacement: step 4, image 1 of 1
      • Remove the last two screws holding the motherboard to the device.
      • Orange Circle: 00 Philips head, Length 2 mm
      Ask FixBot
    5. Controller Plate/Buttons Replacement: step 5, image 1 of 1
      • Gently pull up the motherboard. Some force may need to be applied.
      • Some wires on the reverse side are still attached.
      • Make sure to line up the plastic connectors highlighted by the red circles when re-assembling.
      Ask FixBot
    6. Controller Plate/Buttons Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Break the break the data cable connection between the motherboard and the controller plate by gently pulling out the connecting wire with tweezers.
      • When the device is orientated as shown in the picture, apply the force parallel to the motherboard and away from the device, as depicted by the red arrows.
      Ask FixBot
    7. Controller Plate/Buttons Replacement: step 7, image 1 of 1
      • The entire controller plate should now be free from the phone. All the buttons can now be taken off by gently pressing them out.
      • If the touch-pad joysticks do not work, the entire plate needs to be replaced.
      Ask FixBot
3 other people completed this guide.
Author
with
Pieter Boersma
482 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 125
All Time: 2,243
