Contixo V9 Motherboard Replacement
    1. Contixo V9 Motherboard Replacement, Motherboard: step 1, image 1 of 2 Contixo V9 Motherboard Replacement, Motherboard: step 1, image 2 of 2
      • Find the separation line between the front and back side of the device on the outer edge of the tablet.
      • Use the plastic opening tool to pry apart the tablet, lifting the face off.
      Ask FixBot
    2. Contixo V9 Motherboard Replacement: step 2, image 1 of 3 Contixo V9 Motherboard Replacement: step 2, image 2 of 3 Contixo V9 Motherboard Replacement: step 2, image 3 of 3
      • Remove the three screws along the perimeter of the motherboard using the Phillips #000 screwdriver to unscrew.
      Ask FixBot
    3. Contixo V9 Motherboard Replacement: step 3, image 1 of 3 Contixo V9 Motherboard Replacement: step 3, image 2 of 3 Contixo V9 Motherboard Replacement: step 3, image 3 of 3
      • Locate the three golden ribbons along the perimeter of the motherboard.
      • There are two dark tabs; pull each away from the cream connection port. Once tabs are in open position remove the gold ribbon.
      • Flip up the dark tab and pull the gold ribbon away.
      • Do not pull the the cables harshly as it could rip the ribbon.
      • Reference this guide for more help with attaching or detaching cables.
      Ask FixBot
    4. Contixo V9 Motherboard Replacement: step 4, image 1 of 3 Contixo V9 Motherboard Replacement: step 4, image 2 of 3 Contixo V9 Motherboard Replacement: step 4, image 3 of 3
      • Locate the battery on the opened tablet.
      • Use the spudger or one of the blue iFixit tools to lift the battery from the base of the tablet.
      • It is possible to use your hand to pry the battery away from the base of the tablet but not recommended.
      Ask FixBot
    5. Contixo V9 Motherboard Replacement: step 5, image 1 of 3 Contixo V9 Motherboard Replacement: step 5, image 2 of 3 Contixo V9 Motherboard Replacement: step 5, image 3 of 3
      • Detach the motherboard from the battery by pressing the soldering tip tool to each of the three connection points.
      • Exercise caution when desoldering the battery.
      • The tool located in the pictures is not the soldering tip tool but rather used for reference of where to detach.
      • Reference this guide for more help with soldering and desoldering the connections.
      Ask FixBot
    6. Contixo V9 Motherboard Replacement: step 6, image 1 of 1
      • Remove the motherboard from the base of the device. Switch with replacement.
      Ask FixBot
1 Guide Comment
My motherboard strip is burnt, and need a replacement! Any idea on where I can find an extra? Thanks!!
Jen Staggs - Reply Share
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 47
All Time: 738
