Connect Four Electronic Handheld Speaker Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
79
All Time:
826
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your Connect Four Electronic Handheld does not make any sound, you may need to replace the speaker. This replacement guide will show you how to remove the back casing and remove the speaker. In addition, this guide will also show you how to re-solder the speaker wires.
Parts
Tools
    1. Connect Four Electronic Handheld Speaker Replacement, Ensure the device is off.: step 1, image 1 of 1
      • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
      Ask FixBot
    2. Connect Four Electronic Handheld Speaker Replacement, Removing the battery casing.: step 2, image 1 of 2 Connect Four Electronic Handheld Speaker Replacement, Removing the battery casing.: step 2, image 2 of 2
      • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
      • Slide the cover off and remove the battery.
      Ask FixBot
    1. Connect Four Electronic Handheld Speaker Replacement, Removing/Replacing the Back Casing: step 3, image 1 of 2 Connect Four Electronic Handheld Speaker Replacement, Removing/Replacing the Back Casing: step 3, image 2 of 2
      • Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place.
      • Carefully remove the back casing.
      • When removing the back casing, make sure not to rupture the wires that connect the speaker to the circuit board.
      Ask FixBot
    1. Connect Four Electronic Handheld Speaker Replacement, Replacing the speaker: step 4, image 1 of 3 Connect Four Electronic Handheld Speaker Replacement, Replacing the speaker: step 4, image 2 of 3 Connect Four Electronic Handheld Speaker Replacement, Replacing the speaker: step 4, image 3 of 3
      • If the speaker is in working condition, but the wires are broken or disconnected, skip this step and move on to step 5.
      • Locate the speaker on the back casing.
      • Using a spudger, wedge the speaker out of its place until it slides out.
      • Take the replacement speaker and wedge it back into its space.
      Ask FixBot
    2. Connect Four Electronic Handheld Speaker Replacement, Re-Soldering the Speaker Wire: step 5, image 1 of 1
      • Using a soldering iron, solder both red wires to their appropriate connections.
      • Be extremely careful when using a soldering iron! Contact with the tip could cause severe burns.
      Ask FixBot
Wil
313 Reputation
3 Guides authored
Baylor, Team 8-11, Williams Fall 2014 Member of Baylor, Team 8-11, Williams Fall 2014
BU-WILLIAMS-F14S8G11
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 79
All Time: 826
