Up to 20% off select tools
Connect Four Electronic Handheld Buttons Replacement
Views: 1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
22
Past 30 Days:
87
All Time:
1,023
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If the buttons on your Connect Four have been damaged, you will need to replace them. If the buttons are torn, you will need to purchase a new button sheet. If the buttons are unaligned, simply readjust the button sheet. In order to get to the buttons, you will have to remove the casing on the back of the device. This requires a Phillips head screwdriver.
    1. Connect Four Electronic Handheld Buttons Replacement, Ensure the device is off.: step 1, image 1 of 1
      • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
      Ask FixBot
    2. Connect Four Electronic Handheld Buttons Replacement, Removing the battery casing.: step 2, image 1 of 2 Connect Four Electronic Handheld Buttons Replacement, Removing the battery casing.: step 2, image 2 of 2
      • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
      • Slide the cover off and remove the battery.
      Ask FixBot
    1. Connect Four Electronic Handheld Buttons Replacement, Removing/Replacing the Back Casing: step 3, image 1 of 2 Connect Four Electronic Handheld Buttons Replacement, Removing/Replacing the Back Casing: step 3, image 2 of 2
      • Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place.
      • Carefully remove the back casing.
      • When removing the back casing, make sure not to rupture the wires that connect the speaker to the circuit board.
      Ask FixBot
    1. Connect Four Electronic Handheld Buttons Replacement, Detaching the Circuit Board: step 4, image 1 of 3 Connect Four Electronic Handheld Buttons Replacement, Detaching the Circuit Board: step 4, image 2 of 3 Connect Four Electronic Handheld Buttons Replacement, Detaching the Circuit Board: step 4, image 3 of 3
      • Using a Phillips head screwdriver, remove the six (0.25"-length) #3 screws that hold down the cpu board.
      • Using a spudger, lever the circuit board just enough to where you can easily access the button sheet.
      Ask FixBot
    2. Connect Four Electronic Handheld Buttons Replacement, Removing/ Replacing the Button Sheet: step 5, image 1 of 1
      • Take out the button sheet, and replace it with a new one.
      Ask FixBot
Author
with
Julia Wyder
110 Reputation
1 Guide authored
Baylor, Team 8-11, Williams Fall 2014 Member of Baylor, Team 8-11, Williams Fall 2014
BU-WILLIAMS-F14S8G11
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 87
All Time: 1,023
