Up to 20% off select tools
Connect Four Electronic Handheld Back Casing Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
90
All Time:
799
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
To access any of the internal components of the Connect Four Electronic Handheld, you will need to remove the back casing.
    1. Connect Four Electronic Handheld Back Casing Replacement, Ensure the device is off.: step 1, image 1 of 1
      • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
      Ask FixBot
    2. Connect Four Electronic Handheld Back Casing Replacement, Removing the battery casing.: step 2, image 1 of 2 Connect Four Electronic Handheld Back Casing Replacement, Removing the battery casing.: step 2, image 2 of 2
      • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
      • Slide the cover off and remove the battery.
      Ask FixBot
    1. Connect Four Electronic Handheld Back Casing Replacement, Removing/Replacing the Back Casing: step 3, image 1 of 2 Connect Four Electronic Handheld Back Casing Replacement, Removing/Replacing the Back Casing: step 3, image 2 of 2
      • Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place.
      • Carefully remove the back casing.
      • When removing the back casing, make sure not to rupture the wires that connect the speaker to the circuit board.
      Ask FixBot
Author
with
Wil
313 Reputation
3 Guides authored
Baylor, Team 8-11, Williams Fall 2014 Member of Baylor, Team 8-11, Williams Fall 2014
BU-WILLIAMS-F14S8G11
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 90
All Time: 799
