Up to 20% off select tools
Concept2 Rowing Machine Chain Replacement
Views: 4.7K
View statistics:
Past 24 Hours:
12
Past 7 Days:
43
Past 30 Days:
229
All Time:
4,672
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
If your Concept2 rowing machine isn’t operating as smooth as it used to, it may be time to replace the chain. Replacing the chain on your rowing machine is a relatively simple process and necessary for maintaining your Concept2 machine. Neglecting this maintenance can lead to rust buildup and avoidable damage to other interior parts of your machine.
This guide details the chain replacement of a Model C/D/E Concept2 Rowing Machine. Steps 1 through 7 explain how to properly remove the damaged chain from a rowing machine while steps 8 though 14 detail reassembly.
This guide requires an adjustable wrench and phillips head screwdriver. The replacement parts and tools required for this guide can be purchased on Amazon.
Due to the size and weight of the average rowing machine, it may be in your best interest to find assistance in moving the machine. A majority of the steps in this guide require the machine to be positioned upside down to access the chain and necessary components. To prevent damage to the fan, the machine must be placed down gentle. Working in a wide open space or outdoors is likely in your best interest.
    1. Concept2 Rowing Machine Chain Replacement, Chain: step 1, image 1 of 1
      • Separate the front end of your rower from the seat portion by lifting up the handle in the center.
      • Set aside the seat portion of your rower.
      Ask FixBot
    2. Concept2 Rowing Machine Chain Replacement: step 2, image 1 of 1
      • Turn the front portion of your rower upside down so that the protective covering is facing upwards.
      • Gently slide the protective covering out through the end next to the feet straps.
      • Assistance may be necessary to rotate this portion of the rowing machine. The average weight and size of the fan may be difficult to move alone.
      Ask FixBot
    3. Concept2 Rowing Machine Chain Replacement: step 3, image 1 of 3 Concept2 Rowing Machine Chain Replacement: step 3, image 2 of 3 Concept2 Rowing Machine Chain Replacement: step 3, image 3 of 3
      • Unhook the S.C.A.M. clip from the axel at the end of the rower near the foot straps. This clip is attached to the pulley that runs through the body of the machine.
      Ask FixBot
    4. Concept2 Rowing Machine Chain Replacement: step 4, image 1 of 2 Concept2 Rowing Machine Chain Replacement: step 4, image 2 of 2
      • Using an adjustable wrench and Phillips #00 screwdriver, unscrew the top 31.75 mm (1-1/4") Phillips pan head screw from the metal component at the end of your machine near the foot straps.
      Ask FixBot
    5. Concept2 Rowing Machine Chain Replacement: step 5, image 1 of 3 Concept2 Rowing Machine Chain Replacement: step 5, image 2 of 3 Concept2 Rowing Machine Chain Replacement: step 5, image 3 of 3
      • Remove the two opposing clips from the end of the chain.
      • Note the orientation of these clips for reassembly later on.
      Ask FixBot
    6. Concept2 Rowing Machine Chain Replacement: step 6, image 1 of 1
      • At this point, the chain can be easily removed from the rowing machine.
      Ask FixBot
    7. Concept2 Rowing Machine Chain Replacement: step 7, image 1 of 2 Concept2 Rowing Machine Chain Replacement: step 7, image 2 of 2
      • Use an adjustable wrench to remove nuts from the U-bolt.
      • Remove the U-bolt from the chain.
      • The following steps detail the reassembly of your rowing machine.
      Ask FixBot
    8. Concept2 Rowing Machine Chain Replacement: step 8, image 1 of 1
      • Slide the U-bolt through the end of the new chain and reattach to the handle using an adjustable wrench.
      Ask FixBot
    9. Concept2 Rowing Machine Chain Replacement: step 9, image 1 of 3 Concept2 Rowing Machine Chain Replacement: step 9, image 2 of 3 Concept2 Rowing Machine Chain Replacement: step 9, image 3 of 3
      • Begin to guide the end of the chain opposite the handle back through the rowing machine.
      • Make sure to properly line up the chain with any gears or pulleys inside the machine. These images illustrate key points where the chain should be placed.
      Ask FixBot
    10. Concept2 Rowing Machine Chain Replacement: step 10, image 1 of 3 Concept2 Rowing Machine Chain Replacement: step 10, image 2 of 3 Concept2 Rowing Machine Chain Replacement: step 10, image 3 of 3
      • Guide the new chain around the metal bore at the end near the foot straps.
      • Reattach the two clips from step 5 to the end of your chain and secure back to the metal box component.
      Ask FixBot
    11. Concept2 Rowing Machine Chain Replacement: step 11, image 1 of 1
      • Slide the protective covering through the end of the rowing machine near the foot straps.
      Ask FixBot
    12. Concept2 Rowing Machine Chain Replacement: step 12, image 1 of 1
      • Congratulations! You have successfully replaced the chain on your Concept2 rowing machine.
      Ask FixBot
Author
with
Mariana Hebert
232 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 43
Past 30 Days: 229
All Time: 4,672
