Conair Infiniti Pro Model 259NP Fan Grill Replacement
    1. Conair Infiniti Pro Model 259NP Fan Grill Replacement, Back Panel: step 1, image 1 of 1
      • Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
      • Hold the hair dryer by the handle so that the back panel faces up.
      Ask FixBot
    2. Conair Infiniti Pro Model 259NP Fan Grill Replacement: step 2, image 1 of 2 Conair Infiniti Pro Model 259NP Fan Grill Replacement: step 2, image 2 of 2
      • Remove the two 15.875 mm Phillips #2 screws from the back panel.
      Ask FixBot
    3. Conair Infiniti Pro Model 259NP Fan Grill Replacement: step 3, image 1 of 3 Conair Infiniti Pro Model 259NP Fan Grill Replacement: step 3, image 2 of 3 Conair Infiniti Pro Model 259NP Fan Grill Replacement: step 3, image 3 of 3
      • Starting from where the cord attaches to the handle, pull apart the two plastic panels.
      • Continue separating the back panel, working along the seam.
      • With moderate force, completely remove the back panel from the hair dryer.
      Ask FixBot
    1. Conair Infiniti Pro Model 259NP Fan Grill Replacement, Fan Motor Assembly: step 4, image 1 of 2 Conair Infiniti Pro Model 259NP Fan Grill Replacement, Fan Motor Assembly: step 4, image 2 of 2
      • Hold the hair dryer by the nozzle so that the handle points to the left.
      • Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
      Ask FixBot
    2. Conair Infiniti Pro Model 259NP Fan Grill Replacement: step 5, image 1 of 3 Conair Infiniti Pro Model 259NP Fan Grill Replacement: step 5, image 2 of 3 Conair Infiniti Pro Model 259NP Fan Grill Replacement: step 5, image 3 of 3
      • Caution: If you recently used the hair dryer, wait at least 10 minutes before attempting this step. The heating element may still be very hot and can cause serious burns.
      • Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
      • Lift the attached electrical wiring and heat shield completely out of the hair dryer.
      Ask FixBot
    1. Conair Infiniti Pro Model 259NP Fan Grill Replacement, Fan Grill: step 6, image 1 of 1
      • Hold the front panel of the hair dryer by the nozzle facing upward.
      Ask FixBot
    2. Conair Infiniti Pro Model 259NP Fan Grill Replacement: step 7, image 1 of 2 Conair Infiniti Pro Model 259NP Fan Grill Replacement: step 7, image 2 of 2
      • Using your index finger push the fan grill down with moderate force.
      Ask FixBot
Timothy Lo
1,214 Reputation
7 Guides authored
Cal Poly, Team 10-58, Amido Spring 2014 Member of Cal Poly, Team 10-58, Amido Spring 2014
CPSU-AMIDO-S14S10G58
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 23
All Time: 1,814
