Conair Infiniti Pro Model 259NP Back Panel Replacement
Views: 7.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
101
All Time:
7,317
Comments: 0
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
In order to replace any internal parts, you first need to take off the back panel of the hair dryer. This guide will show you how to do that.
Tools
    1. Conair Infiniti Pro Model 259NP Back Panel Replacement, Back Panel: step 1, image 1 of 1
      • Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
      • Hold the hair dryer by the handle so that the back panel faces up.
      Ask FixBot
    2. Conair Infiniti Pro Model 259NP Back Panel Replacement: step 2, image 1 of 2 Conair Infiniti Pro Model 259NP Back Panel Replacement: step 2, image 2 of 2
      • Remove the two 15.875 mm Phillips #2 screws from the back panel.
      Ask FixBot
    3. Conair Infiniti Pro Model 259NP Back Panel Replacement: step 3, image 1 of 3 Conair Infiniti Pro Model 259NP Back Panel Replacement: step 3, image 2 of 3 Conair Infiniti Pro Model 259NP Back Panel Replacement: step 3, image 3 of 3
      • Starting from where the cord attaches to the handle, pull apart the two plastic panels.
      • Continue separating the back panel, working along the seam.
      • With moderate force, completely remove the back panel from the hair dryer.
      Ask FixBot
6 other people completed this guide.
Timothy Lo
1,214 Reputation
7 Guides authored
Cal Poly, Team 10-58, Amido Spring 2014 Member of Cal Poly, Team 10-58, Amido Spring 2014
CPSU-AMIDO-S14S10G58
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 101
All Time: 7,317
