Computer King Muffin Kinder 7 Screen Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
94
All Time:
889
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓
To complete this guide, you will need to disassemble your device in order to get to the screen to replace it.
Make sure to power off the device before you begin to take apart your device. Not doing so could potentially cause harm.
Tools
    1. Computer King Muffin Kinder 7 Screen Replacement, Screen: step 1, image 1 of 2 Computer King Muffin Kinder 7 Screen Replacement, Screen: step 1, image 2 of 2
      • Use the plastic opening tool help push out the microSD card from the microSD slot.
      Ask FixBot
    2. Computer King Muffin Kinder 7 Screen Replacement: step 2, image 1 of 1
      • Use the plastic opening tool to unclip the plastic front from the plastic back. Use the MicroSD slot to initially start the unclipping.
      Ask FixBot
    3. Computer King Muffin Kinder 7 Screen Replacement: step 3, image 1 of 2 Computer King Muffin Kinder 7 Screen Replacement: step 3, image 2 of 2
      • Unscrew the nine 3.0 mm Phillips #00 screws.
      Ask FixBot
    4. Computer King Muffin Kinder 7 Screen Replacement: step 4, image 1 of 1
      • The battery is glued onto the black plastic. Use the plastic opening tool to pry the battery from the black plastic
      Ask FixBot
    5. Computer King Muffin Kinder 7 Screen Replacement: step 5, image 1 of 2 Computer King Muffin Kinder 7 Screen Replacement: step 5, image 2 of 2
      • There will be a black strip connected to the screen.
      • Use the pointy end of the spudger to unstick the black strip that is glued onto the screen.
      Ask FixBot
    6. Computer King Muffin Kinder 7 Screen Replacement: step 6, image 1 of 3 Computer King Muffin Kinder 7 Screen Replacement: step 6, image 2 of 3 Computer King Muffin Kinder 7 Screen Replacement: step 6, image 3 of 3
      • You will need to remove 2 ribbon cables, one that is connected to the touch screen (by the battery) and one that is connected to the yellow plastic (by the speaker).
      • Use the flat end of the spudger to lift the black panel covering the ribbon cables.
      Ask FixBot
    7. Computer King Muffin Kinder 7 Screen Replacement: step 7, image 1 of 1
      • Pull the two ribbon cables out so that they are no longer connected to the logic board.
      Ask FixBot
    8. Computer King Muffin Kinder 7 Screen Replacement: step 8, image 1 of 1
      • Lift up the logic board and black plastic so that they are no longer covering the screen
      • Lift out the screen.
      Ask FixBot
3 other people completed this guide.
Katherine
439 Reputation
3 Guides authored
UWT Liner: Group 2 Member of UWT Liner: Group 2
Community
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 94
All Time: 889
