Compression Test
  1. Compression Test, Safety precautions: step 1, image 1 of 2 Compression Test, Safety precautions: step 1, image 2 of 2
    • Flip the power switch into the STOP position.
    • Make sure the engine is cool to the touch before proceeding.
    Ask FixBot
  2. Compression Test, Remove the spark plug cap: step 2, image 1 of 2 Compression Test, Remove the spark plug cap: step 2, image 2 of 2
    • Pull the spark plug cap straight off of the spark plug.
    Ask FixBot
  3. Compression Test, Remove the spark plug: step 3, image 1 of 1
    • Use a 5/8-inch spark plug socket to remove the spark plug from the engine.
    Ask FixBot
  4. Compression Test, Check the spark plug for wear: step 4, image 1 of 1
    • Check if the spark plug is fouled and replace it if necessary.
    • The spark plug pictured in this step is in new condition.
    Ask FixBot
  5. Compression Test, Connect a compression tester: step 5, image 1 of 1
    • Follow the instruction provided with your compression test kit to connect a compression tester to the cylinder.
    Ask FixBot
  6. Compression Test, Test compression: step 6, image 1 of 2 Compression Test, Test compression: step 6, image 2 of 2
    • Pull the starter 5–10 times to build pressure in the combustion chamber.
    Ask FixBot
  7. Compression Test: step 7, image 1 of 1
    • Read the compression gauge.
    • Pressure should read 125–165 psi (8.6–11.4 bar).
    Ask FixBot
2 other people completed this guide.
Sam Omiotek
99,430 Reputation
290 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 28
All Time: 1,009
