Up to 20% off select tools
Compaq Presario v2000 RAM Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
72
All Time:
725
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 seconds - 2 minutes
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
This is a guide on how to replace the RAM for a Compaq Presario V2000.
    1. Compaq Presario v2000 RAM Replacement, Removing the RAM cover: step 1, image 1 of 2 Compaq Presario v2000 RAM Replacement, Removing the RAM cover: step 1, image 2 of 2
      • Loosen the 2 Phillips screws with RAM icons above them. Don’t worry if the screws won’t come out, as they’re attached to the door.
      • Lift the RAM door up and away.
      Ask FixBot
    2. Compaq Presario v2000 RAM Replacement, Removing the existing RAM: step 2, image 1 of 3 Compaq Presario v2000 RAM Replacement, Removing the existing RAM: step 2, image 2 of 3 Compaq Presario v2000 RAM Replacement, Removing the existing RAM: step 2, image 3 of 3
      • There are two metal clips holding both RAM modules in place.
      • To unclip them, push them both outwards from the RAM stick with your fingers until it pops out and sticks up at an angle.
      • Pull the stick of RAM out.
      • Repeat the last 3 steps for the bottom RAM stick.
      Ask FixBot
    3. Compaq Presario v2000 RAM Replacement, Installing the new RAM: step 3, image 1 of 2 Compaq Presario v2000 RAM Replacement, Installing the new RAM: step 3, image 2 of 2
      • Start at the bottom slot. Insert the new RAM at the same angle the previous RAM popped out at.
      • Push the RAM in until a click is heard.
      • Repeat the last 2 steps for the top slot.
      Ask FixBot
    4. Compaq Presario v2000 RAM Replacement, Reinstalling the RAM cover: step 4, image 1 of 1
      • Repeat the first part of this guide to reinstall the RAM door.
      Ask FixBot
If you encounter problems after installing new RAM, redo this guide, or follow a RAM troubleshooting guide.
Author
with
Viscous
403 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 72
All Time: 725
