Compaq Presario v2000 Hard drive Replacement
Views: 11K
View statistics:
Past 24 Hours:
4
Past 7 Days:
32
Past 30 Days:
115
All Time:
11,436
Comments: 1
1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
    1. Compaq Presario v2000 Hard drive Replacement, Hard drive: step 1, image 1 of 1
      • Remove the battery before starting
      Ask FixBot
    2. Compaq Presario v2000 Hard drive Replacement: step 2, image 1 of 2 Compaq Presario v2000 Hard drive Replacement: step 2, image 2 of 2
      • Loosen the two screw for the hard drive cover
      • The screws will stay attached the the cover
      • Lift the cover from the left side and remove
      Ask FixBot
    3. Compaq Presario v2000 Hard drive Replacement: step 3, image 1 of 2 Compaq Presario v2000 Hard drive Replacement: step 3, image 2 of 2
      • Lift the black pull tab on the hard drive
      • Lift the drive straight up out of the laptop
      Ask FixBot
    4. Compaq Presario v2000 Hard drive Replacement: step 4, image 1 of 2 Compaq Presario v2000 Hard drive Replacement: step 4, image 2 of 2
      • Remove the four screws on the sides of the drive (two on each side)
      • Remove the hard drive from the caddy
      Ask FixBot
    5. Compaq Presario v2000 Hard drive Replacement: step 5, image 1 of 1
      • Pull the IDE connecter straight off the drive
      • Be sure to pull the connecter off straight so as not to bend the hard drive IDE pins
      Ask FixBot
4 other people completed this guide.
Andrew
1,438 Reputation
5 Guides authored
1 Guide Comment
Perfect instructions....easy directions even for a computer dunce like me...
John Platania - Reply Share
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 115
All Time: 11,436
