Up to 20% off select tools
Compaq Presario v2000 Display Panel Replacement
Views: 4.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
90
All Time:
4,920
Comments: 2
2 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
How to remove and replace the LCD display panel
    1. Compaq Presario v2000 Display Panel Replacement, Display Panel: step 1, image 1 of 1
      • Remove the battery before starting working on the laptop
      Ask FixBot
    2. Compaq Presario v2000 Display Panel Replacement: step 2, image 1 of 3 Compaq Presario v2000 Display Panel Replacement: step 2, image 2 of 3 Compaq Presario v2000 Display Panel Replacement: step 2, image 3 of 3
      • There are 6 screws holding on the display bezel, hidden behind screw covers
      • Remove the screw covers with a spudger or small flat blade screwdriver
      • Remove the screws with a phillips #1 screwdriver
      Ask FixBot
    3. Compaq Presario v2000 Display Panel Replacement: step 3, image 1 of 3 Compaq Presario v2000 Display Panel Replacement: step 3, image 2 of 3 Compaq Presario v2000 Display Panel Replacement: step 3, image 3 of 3
      • Use your fingers to pry off the bezel at the top and sides first
      • Don't use anything hard and sharp as you may damage the panel
      • You may need to use a spudger or flat blade screwdriver at the bottom edge around the hinges
      Ask FixBot
    4. Compaq Presario v2000 Display Panel Replacement: step 4, image 1 of 1
      • Remove the backlight inverter cable using a spudger or flat blade screwdriver
      Ask FixBot
    5. Compaq Presario v2000 Display Panel Replacement: step 5, image 1 of 2 Compaq Presario v2000 Display Panel Replacement: step 5, image 2 of 2
      • Remove the two side screws at the top of the panel first
      • Then remove the two side screws at the bottom. It may be necessary to angle the display away from the back cover to reach these well
      • Hold on to the display when removing the last screw, there is still a cable on the back to remove
      Ask FixBot
    6. Compaq Presario v2000 Display Panel Replacement: step 6, image 1 of 3 Compaq Presario v2000 Display Panel Replacement: step 6, image 2 of 3 Compaq Presario v2000 Display Panel Replacement: step 6, image 3 of 3
      • Lay the panel down on the keyboard
      • Remove the tape covering the display cable connecter
      • Remove the display cable from the panel
      Ask FixBot
6 other people completed this guide.
Author
with
Andrew
1,438 Reputation
5 Guides authored
2 Guide Comments
Do you know where I can buy the replacement screen being replaced?
Amanda Turner - Reply Share
Laptop panels are fairly generic, you don't need an HP screen for an HP laptop for example. There are numerous places selling them including laptop screen.com, or on eBay. Be sure to get the same size, resolution, backlight type, and connector as the screen you are replacing. Often there is a sticker on the back of the screen with a model code you can search for (e.g.. LP140WH3)
Andrew - Reply Share
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 90
All Time: 4,920
