Compaq Presario V2414NR RAM Replacement
    1. Compaq Presario V2414NR RAM Replacement, Battery: step 1, image 1 of 1
      • Shutdown the computer.
      • Remove all external devices.
      • Unplug the power, and any other cords, from the laptop.
      • Turn the laptop upside down, with the front towards you.
      Ask FixBot
    2. Compaq Presario V2414NR RAM Replacement: step 2, image 1 of 2 Compaq Presario V2414NR RAM Replacement: step 2, image 2 of 2
      • Slide the battery release latch to the left until the battery pops up.
      • Lift the front edge of the battery pack and swing it back to remove it.
      • When reassembling, first align the back of the battery with the chassis, then press the front downwards until it latches.
      Ask FixBot
    1. Compaq Presario V2414NR RAM Replacement, RAM Cover: step 3, image 1 of 2 Compaq Presario V2414NR RAM Replacement, RAM Cover: step 3, image 2 of 2
      • Loosen the two 5mm Phillips #1 screws that secure the memory module compartment cover to the computer.
      • These screws are captured to the cover panel.
      • Lift the front edge of the memory module compartment cover and swing it back to remove it.
      Ask FixBot
    1. Compaq Presario V2414NR RAM Replacement, RAM: step 4, image 1 of 2 Compaq Presario V2414NR RAM Replacement, RAM: step 4, image 2 of 2
      • Use your fingers, or plastic opening tools, to spread the metal retaining tabs on each side of the RAM outwards until the module pops up.
      • Pull the module out of the socket at the same angle it is now oriented.
      • Repeat these steps to remove the second memory module.
      • When reassembling, align the offset notch on the RAM contacts with the tab on the socket and insert at a 30 degree angle.
      Ask FixBot
Rylie Schmidt
765 Reputation
7 Guides authored
UMass Dartmouth, Team 2-1, Isaacson Fall 2016 Member of UMass Dartmouth, Team 2-1, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G1
3 Members
82 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 29
All Time: 591
