Compaq Presario CQ62-215dx RAM Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
59
All Time:
1,129
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Running out of memory can cause your laptop to slow down. It’s important to upgrade your RAM to optimize its performance. Upgrading your RAM is well worth it because it can prolong its lifespan.
Parts
Tools
    1. Compaq Presario CQ62-215dx RAM Replacement, RAM: step 1, image 1 of 1
      • lay the laptop upside down.
      Ask FixBot
    2. Compaq Presario CQ62-215dx RAM Replacement: step 2, image 1 of 1
      • Remove the battery by pushing the lock to the left and lifting the battery from its socket.
      Ask FixBot
    3. Compaq Presario CQ62-215dx RAM Replacement: step 3, image 1 of 1
      • Once the battery is out, locate a panel that is underneath the battery compartment and unscrew the three 3mm screws with a Philips screwdriver.
      Ask FixBot
    4. Compaq Presario CQ62-215dx RAM Replacement: step 4, image 1 of 1
      • Once removed, you should have something like in this picture. Locate the current RAM.
      Ask FixBot
    5. Compaq Presario CQ62-215dx RAM Replacement: step 5, image 1 of 1
      • To remove the RAM, start by lifting up the first card. Grab each side of the card with two fingers as shown in the picture and pull gently until it is removed from its slot.
      Ask FixBot
    6. Compaq Presario CQ62-215dx RAM Replacement: step 6, image 1 of 1
      • Insert your new RAM replacement into the slot where the old one was removed. Push until you hear a small click.
      Ask FixBot
    7. Compaq Presario CQ62-215dx RAM Replacement: step 7, image 1 of 1
      • Push the card downward into the compartment until you hear another clicking sound.
      Ask FixBot
Breana Thibodeaux
760 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 59
All Time: 1,129
