Compaq Presario CQ62-215dx CPU Replacement
  1. Compaq Presario CQ62-215dx CPU Replacement, CPU: step 1, image 1 of 1
    • Turn the laptop upside down.
    • Remove all the 3.0mm Phillips #00 screws from the back cover.
    Ask FixBot
  2. Compaq Presario CQ62-215dx CPU Replacement: step 2, image 1 of 1
    • Remove the battery, RAM, and hard drive.
    Ask FixBot
  3. Compaq Presario CQ62-215dx CPU Replacement: step 3, image 1 of 1
    • Remove four 1.2mm Phillips #00 screws under the battery.
    Ask FixBot
  4. Compaq Presario CQ62-215dx CPU Replacement: step 4, image 1 of 1
    • Turn the laptop over, and open the laptop cover.
    • Use a spudger or your hand to carefully remove the keyboard.
    Ask FixBot
  5. Compaq Presario CQ62-215dx CPU Replacement: step 5, image 1 of 1
    • Use a spudger or your hand to lift the outside frame from the corner of the laptop.
    Ask FixBot
  6. Compaq Presario CQ62-215dx CPU Replacement: step 6, image 1 of 1
    • Remove all the 1.2mm Phillips #00 screws from the motherboard and in the top corner that secures the fan.
    Ask FixBot
  7. Compaq Presario CQ62-215dx CPU Replacement: step 7, image 1 of 1
    • Unplug the wires connected to the motherboard with a spudger.
    Ask FixBot
  8. Compaq Presario CQ62-215dx CPU Replacement: step 8, image 1 of 1
    • Remove the two 3mm Phillips #00 screws beside the fan.
    Ask FixBot
  9. Compaq Presario CQ62-215dx CPU Replacement: step 9, image 1 of 1
    • Lift the motherboard out carefully.
    Ask FixBot
  10. Compaq Presario CQ62-215dx CPU Replacement: step 10, image 1 of 1
    • When the motherboard is removed, flip it over, and you will have a view just like in the picture.
    Ask FixBot
  11. Compaq Presario CQ62-215dx CPU Replacement: step 11, image 1 of 1
    • Use the Phillips #00 screwdriver to remove the three 2mm screws that connect the fan to the CPU.
    Ask FixBot
  12. Compaq Presario CQ62-215dx CPU Replacement: step 12, image 1 of 1
    • Remove the fan from the motherboard.
    • When reassembling, you will need to solder the fan back on to the CPU.
    Ask FixBot
  13. Compaq Presario CQ62-215dx CPU Replacement: step 13, image 1 of 1
    • Use the metal spudger to twist the lock tab on the component.
    Ask FixBot
  14. Compaq Presario CQ62-215dx CPU Replacement: step 14, image 1 of 1
    • Remove current CPU and replace with new component.
    Ask FixBot
Breana Thibodeaux
760 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 36
All Time: 1,848
