Compaq Presario CQ60-211DX Display Assembly Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
60
All Time:
1,871
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
This guide will show how to remove and replace the display assembly on a Compaq Presario CQ60-211DX laptop.
Tools
    1. Compaq Presario CQ60-211DX Display Assembly Replacement, Display Assembly: step 1, image 1 of 1
      • Start by making sure the CQ60 is powered down and that the disk drive is empty.
      • Flip the device over and remove the battery.
      Ask FixBot
    2. Compaq Presario CQ60-211DX Display Assembly Replacement: step 2, image 1 of 2 Compaq Presario CQ60-211DX Display Assembly Replacement: step 2, image 2 of 2
      • Remove the rubber screw covers next to each of the two screen hinges using a metal spudger.
      • Unscrew the screws underneath the rubber cover using the blank Phillips-head screwdriver.
      Ask FixBot
    3. Compaq Presario CQ60-211DX Display Assembly Replacement: step 3, image 1 of 2 Compaq Presario CQ60-211DX Display Assembly Replacement: step 3, image 2 of 2
      • Use the metal spudger to gently pry the plastic faceplate off the rest of the display.
      Ask FixBot
    4. Compaq Presario CQ60-211DX Display Assembly Replacement: step 4, image 1 of 1
      • Unscrew the two screws in the top corners to separate the frame holding the assembly from the plastic of the lid.
      Ask FixBot
    5. Compaq Presario CQ60-211DX Display Assembly Replacement: step 5, image 1 of 1
      • Disconnect the assembly from the chip located between the hinges by pulling the wires to the right.
      Ask FixBot
    6. Compaq Presario CQ60-211DX Display Assembly Replacement: step 6, image 1 of 1
      • Pull the frame forward, and then unscrew the three screws on each side.
      Ask FixBot
    7. Compaq Presario CQ60-211DX Display Assembly Replacement: step 7, image 1 of 1
      • Disconnect the ribbon cable on the back of the display by peeling back the tape and then pulling down on the cable.
      Ask FixBot
2 other people completed this guide.
2 Guide Comments
My laptop model Compaq predario cq61 h
Rashid 007 - Reply Share
Computer on but display light of computer is running
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 60
All Time: 1,871
