Compaq Presario CQ60 Keyboard Bezel Replacement
    1. Compaq Presario CQ60 Keyboard Bezel Replacement, Slide battery latch: step 1, image 1 of 2 Compaq Presario CQ60 Keyboard Bezel Replacement, Slide battery latch: step 1, image 2 of 2
      • Slide battery latch to left
      • Simultaneously lift battery
      Ask FixBot
    2. Compaq Presario CQ60 Keyboard Bezel Replacement: step 2, image 1 of 3 Compaq Presario CQ60 Keyboard Bezel Replacement: step 2, image 2 of 3 Compaq Presario CQ60 Keyboard Bezel Replacement: step 2, image 3 of 3
      • Lift and remove battery
      Ask FixBot
    1. Compaq Presario CQ60 Keyboard Bezel Replacement, Unscrew keyboard: step 3, image 1 of 2 Compaq Presario CQ60 Keyboard Bezel Replacement, Unscrew keyboard: step 3, image 2 of 2
      • Remove 3x M2.5x4mm
      Ask FixBot
    2. Compaq Presario CQ60 Keyboard Bezel Replacement, Lift keyboard: step 4, image 1 of 3 Compaq Presario CQ60 Keyboard Bezel Replacement, Lift keyboard: step 4, image 2 of 3 Compaq Presario CQ60 Keyboard Bezel Replacement, Lift keyboard: step 4, image 3 of 3
      • Lift the keyboard in the middle with a spudger
      • Remove 4 clips by bending keyboard in middle, do not force the clips at the sides
      • Do not remove the keyboard fully, it is attached via a ribbon cable
      Ask FixBot
    3. Compaq Presario CQ60 Keyboard Bezel Replacement, Detach ribbon cable: step 5, image 1 of 3 Compaq Presario CQ60 Keyboard Bezel Replacement, Detach ribbon cable: step 5, image 2 of 3 Compaq Presario CQ60 Keyboard Bezel Replacement, Detach ribbon cable: step 5, image 3 of 3
      • Lift keyboard slightly
      • Push each side of ribbon cable connector
      • Fully remove keyboard
      Ask FixBot
    1. Compaq Presario CQ60 Keyboard Bezel Replacement, Remove screws: step 6, image 1 of 3 Compaq Presario CQ60 Keyboard Bezel Replacement, Remove screws: step 6, image 2 of 3 Compaq Presario CQ60 Keyboard Bezel Replacement, Remove screws: step 6, image 3 of 3
      • Remove 2x Phillips M2.5x8mm screws from under the display
      • Remove 4x Phillips M2x2.8mm screws from the battery compartment
      Ask FixBot
    2. Compaq Presario CQ60 Keyboard Bezel Replacement, Disconnect ribbon cable: step 7, image 1 of 3 Compaq Presario CQ60 Keyboard Bezel Replacement, Disconnect ribbon cable: step 7, image 2 of 3 Compaq Presario CQ60 Keyboard Bezel Replacement, Disconnect ribbon cable: step 7, image 3 of 3
      • Turn over the laptop
      • Use a spudger to lift the ribbon cable hinged clip
      • Pull the ribbon cable out of the connector
      Ask FixBot
    3. Compaq Presario CQ60 Keyboard Bezel Replacement: step 8, image 1 of 2 Compaq Presario CQ60 Keyboard Bezel Replacement: step 8, image 2 of 2
      • Lifting the bezel by the screen
      • Slide the bezel back towards the screen to release it from the clips
      Ask FixBot
    4. Compaq Presario CQ60 Keyboard Bezel Replacement, Remove bezel: step 9, image 1 of 1
      • Fully remove bezel
      Ask FixBot
Mike B
1,045 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 29
All Time: 627
