Compaq Presario CQ60 Display Assembly Replacement
    1. Compaq Presario CQ60 Display Assembly Replacement, Slide battery latch: step 1, image 1 of 2 Compaq Presario CQ60 Display Assembly Replacement, Slide battery latch: step 1, image 2 of 2
      • Slide battery latch to left
      • Simultaneously lift battery
      Ask FixBot
    2. Compaq Presario CQ60 Display Assembly Replacement: step 2, image 1 of 3 Compaq Presario CQ60 Display Assembly Replacement: step 2, image 2 of 3 Compaq Presario CQ60 Display Assembly Replacement: step 2, image 3 of 3
      • Lift and remove battery
      Ask FixBot
    1. Compaq Presario CQ60 Display Assembly Replacement, Unscrew keyboard: step 3, image 1 of 2 Compaq Presario CQ60 Display Assembly Replacement, Unscrew keyboard: step 3, image 2 of 2
      • Remove 3x M2.5x4mm
      Ask FixBot
    2. Compaq Presario CQ60 Display Assembly Replacement, Lift keyboard: step 4, image 1 of 3 Compaq Presario CQ60 Display Assembly Replacement, Lift keyboard: step 4, image 2 of 3 Compaq Presario CQ60 Display Assembly Replacement, Lift keyboard: step 4, image 3 of 3
      • Lift the keyboard in the middle with a spudger
      • Remove 4 clips by bending keyboard in middle, do not force the clips at the sides
      • Do not remove the keyboard fully, it is attached via a ribbon cable
      Ask FixBot
    3. Compaq Presario CQ60 Display Assembly Replacement, Detach ribbon cable: step 5, image 1 of 3 Compaq Presario CQ60 Display Assembly Replacement, Detach ribbon cable: step 5, image 2 of 3 Compaq Presario CQ60 Display Assembly Replacement, Detach ribbon cable: step 5, image 3 of 3
      • Lift keyboard slightly
      • Push each side of ribbon cable connector
      • Fully remove keyboard
      Ask FixBot
    1. Compaq Presario CQ60 Display Assembly Replacement, Remove screws: step 6, image 1 of 3 Compaq Presario CQ60 Display Assembly Replacement, Remove screws: step 6, image 2 of 3 Compaq Presario CQ60 Display Assembly Replacement, Remove screws: step 6, image 3 of 3
      • Remove 2x Phillips M2.5x8mm screws from under the display
      • Remove 4x Phillips M2x2.8mm screws from the battery compartment
      Ask FixBot
    2. Compaq Presario CQ60 Display Assembly Replacement, Disconnect ribbon cable: step 7, image 1 of 3 Compaq Presario CQ60 Display Assembly Replacement, Disconnect ribbon cable: step 7, image 2 of 3 Compaq Presario CQ60 Display Assembly Replacement, Disconnect ribbon cable: step 7, image 3 of 3
      • Turn over the laptop
      • Use a spudger to lift the ribbon cable hinged clip
      • Pull the ribbon cable out of the connector
      Ask FixBot
    3. Compaq Presario CQ60 Display Assembly Replacement: step 8, image 1 of 2 Compaq Presario CQ60 Display Assembly Replacement: step 8, image 2 of 2
      • Lifting the bezel by the screen
      • Slide the bezel back towards the screen to release it from the clips
      Ask FixBot
    4. Compaq Presario CQ60 Display Assembly Replacement, Remove bezel: step 9, image 1 of 1
      • Fully remove bezel
      Ask FixBot
    1. Compaq Presario CQ60 Display Assembly Replacement, Disconnect left hand cables: step 10, image 1 of 2 Compaq Presario CQ60 Display Assembly Replacement, Disconnect left hand cables: step 10, image 2 of 2
      • Disconnect the display cable
      • Disconnect the microphone connector
      • Pull out the microphone LED from it's clip
      • Unroute the cables from their holders
      Ask FixBot
    2. Compaq Presario CQ60 Display Assembly Replacement, Wifi Antennas: step 11, image 1 of 3 Compaq Presario CQ60 Display Assembly Replacement, Wifi Antennas: step 11, image 2 of 3 Compaq Presario CQ60 Display Assembly Replacement, Wifi Antennas: step 11, image 3 of 3
      • Pull the wifi antennas through from the back of the laptop
      • Unroute the antenna cables from their guides
      Ask FixBot
    3. Compaq Presario CQ60 Display Assembly Replacement, Remove display assembly: step 12, image 1 of 3 Compaq Presario CQ60 Display Assembly Replacement, Remove display assembly: step 12, image 2 of 3 Compaq Presario CQ60 Display Assembly Replacement, Remove display assembly: step 12, image 3 of 3
      • Remove 4x Phillips #1 M2.5x8mm screws from display hinges
      • Carefully lift display out making sure no cables are snagged
      Ask FixBot
2 other people completed this guide.
Mike B
1,045 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 34
All Time: 1,298
