Up to 20% off select tools
Compaq Mini 110 Top Cover Replacement
Views: 9.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
101
All Time:
9,062
Comments: 4
4 comments on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
  • Spudger
    4.9
  • Phillips #0 Screwdriver
    5
    1. Compaq Mini 110 Top Cover Replacement, Battery: step 1, image 1 of 2 Compaq Mini 110 Top Cover Replacement, Battery: step 1, image 2 of 2
      • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
      Ask FixBot
    2. Compaq Mini 110 Top Cover Replacement: step 2, image 1 of 3 Compaq Mini 110 Top Cover Replacement: step 2, image 2 of 3 Compaq Mini 110 Top Cover Replacement: step 2, image 3 of 3
      • Push both tabs inward simultaneously and slide the battery out.
      Ask FixBot
    1. Compaq Mini 110 Top Cover Replacement, RAM: step 3, image 1 of 2 Compaq Mini 110 Top Cover Replacement, RAM: step 3, image 2 of 2
      • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
      Ask FixBot
    2. Compaq Mini 110 Top Cover Replacement: step 4, image 1 of 1
      • Push out the side tabs simultaneously and pull out the old RAM module.
      • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
      Ask FixBot
    1. Compaq Mini 110 Top Cover Replacement, Keyboard: step 5, image 1 of 2 Compaq Mini 110 Top Cover Replacement, Keyboard: step 5, image 2 of 2
      • Remove the rubber pads located on the corners of your Compaq Mini.
      • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
      Ask FixBot
    2. Compaq Mini 110 Top Cover Replacement: step 6, image 1 of 2 Compaq Mini 110 Top Cover Replacement: step 6, image 2 of 2
      • Unscrew all the corner screws. There are four total, one under each rubber pad.
      Ask FixBot
    3. Compaq Mini 110 Top Cover Replacement: step 7, image 1 of 2 Compaq Mini 110 Top Cover Replacement: step 7, image 2 of 2
      • Unscrew the screw for the bottom case located in the RAM compartment.
      Ask FixBot
    4. Compaq Mini 110 Top Cover Replacement: step 8, image 1 of 2 Compaq Mini 110 Top Cover Replacement: step 8, image 2 of 2
      • Remove the three screws in the silver tabs at the back of the keyboard.
      • These are located at the back of the base under the screen.
      • Lift the keyboard away from the laptop.
      Ask FixBot
    1. Compaq Mini 110 Top Cover Replacement, Hard Drive: step 9, image 1 of 1
      • Remove the three screws holding the panel in place.
      Ask FixBot
    2. Compaq Mini 110 Top Cover Replacement: step 10, image 1 of 2 Compaq Mini 110 Top Cover Replacement: step 10, image 2 of 2
      • Pull up on the tab to remove the hard drive.
      Ask FixBot
    1. Compaq Mini 110 Top Cover Replacement, Top Cover: step 11, image 1 of 1
      • Remove the eight screws that are from the plastic top cover.
      Ask FixBot
    2. Compaq Mini 110 Top Cover Replacement: step 12, image 1 of 3 Compaq Mini 110 Top Cover Replacement: step 12, image 2 of 3 Compaq Mini 110 Top Cover Replacement: step 12, image 3 of 3
      • Pry up the top plastic cover using a spudger.
      • These two tabs under the screen need to be pushed in with a spudger.
      Ask FixBot
    3. Compaq Mini 110 Top Cover Replacement: step 13, image 1 of 2 Compaq Mini 110 Top Cover Replacement: step 13, image 2 of 2
      • Remove the cable by carefully pulling it up.
      • Be careful when lifting up the cover because the track pad is still attached.
      Ask FixBot
4 other people completed this guide.
Author
with
alea
1,441 Reputation
14 Guides authored
Cal Poly, Team 22-2, Maness Fall 2010 Member of Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
6 Members
180 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 101
All Time: 9,062
