Up to 20% off select tools
Compaq Mini 110 Screen Replacement
Views: 12K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
80
All Time:
12,282
Comments: 4
4 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
  • Spudger
    4.9
  • Phillips #0 Screwdriver
    5
Introduction
Go to step 1 ↓
Maybe it's cracked. Maybe you brought a magnet too close to it. Either way, the screen needs replacing and here's how to do it.
    1. Compaq Mini 110 Screen Replacement, Battery: step 1, image 1 of 2 Compaq Mini 110 Screen Replacement, Battery: step 1, image 2 of 2
      • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
      Ask FixBot
    2. Compaq Mini 110 Screen Replacement: step 2, image 1 of 3 Compaq Mini 110 Screen Replacement: step 2, image 2 of 3 Compaq Mini 110 Screen Replacement: step 2, image 3 of 3
      • Push both tabs inward simultaneously and slide the battery out.
      Ask FixBot
    1. Compaq Mini 110 Screen Replacement, RAM: step 3, image 1 of 2 Compaq Mini 110 Screen Replacement, RAM: step 3, image 2 of 2
      • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
      Ask FixBot
    2. Compaq Mini 110 Screen Replacement: step 4, image 1 of 1
      • Push out the side tabs simultaneously and pull out the old RAM module.
      • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
      Ask FixBot
    1. Compaq Mini 110 Screen Replacement, Keyboard: step 5, image 1 of 2 Compaq Mini 110 Screen Replacement, Keyboard: step 5, image 2 of 2
      • Remove the rubber pads located on the corners of your Compaq Mini.
      • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
      Ask FixBot
    2. Compaq Mini 110 Screen Replacement: step 6, image 1 of 2 Compaq Mini 110 Screen Replacement: step 6, image 2 of 2
      • Unscrew all the corner screws. There are four total, one under each rubber pad.
      Ask FixBot
    3. Compaq Mini 110 Screen Replacement: step 7, image 1 of 2 Compaq Mini 110 Screen Replacement: step 7, image 2 of 2
      • Unscrew the screw for the bottom case located in the RAM compartment.
      Ask FixBot
    4. Compaq Mini 110 Screen Replacement: step 8, image 1 of 2 Compaq Mini 110 Screen Replacement: step 8, image 2 of 2
      • Remove the three screws in the silver tabs at the back of the keyboard.
      • These are located at the back of the base under the screen.
      • Lift the keyboard away from the laptop.
      Ask FixBot
    1. Compaq Mini 110 Screen Replacement, Hard Drive: step 9, image 1 of 1
      • Remove the three screws holding the panel in place.
      Ask FixBot
    2. Compaq Mini 110 Screen Replacement: step 10, image 1 of 2 Compaq Mini 110 Screen Replacement: step 10, image 2 of 2
      • Pull up on the tab to remove the hard drive.
      Ask FixBot
    1. Compaq Mini 110 Screen Replacement, Top Cover: step 11, image 1 of 1
      • Remove the eight screws that are from the plastic top cover.
      Ask FixBot
    2. Compaq Mini 110 Screen Replacement: step 12, image 1 of 3 Compaq Mini 110 Screen Replacement: step 12, image 2 of 3 Compaq Mini 110 Screen Replacement: step 12, image 3 of 3
      • Pry up the top plastic cover using a spudger.
      • These two tabs under the screen need to be pushed in with a spudger.
      Ask FixBot
    3. Compaq Mini 110 Screen Replacement: step 13, image 1 of 2 Compaq Mini 110 Screen Replacement: step 13, image 2 of 2
      • Remove the cable by carefully pulling it up.
      • Be careful when lifting up the cover because the track pad is still attached.
      Ask FixBot
    1. Compaq Mini 110 Screen Replacement, Display Assembly: step 14, image 1 of 3 Compaq Mini 110 Screen Replacement, Display Assembly: step 14, image 2 of 3 Compaq Mini 110 Screen Replacement, Display Assembly: step 14, image 3 of 3
      • Remove the four screws that keep the bottom of the hinges attached to the base.
      Ask FixBot
    2. Compaq Mini 110 Screen Replacement: step 15, image 1 of 3 Compaq Mini 110 Screen Replacement: step 15, image 2 of 3 Compaq Mini 110 Screen Replacement: step 15, image 3 of 3
      • Pry off the top plastic cover of the display assembly.
      • The spudger may go all the way through to the screen-side of the cover. This is not a problem and won't damage anything.
      • There is adhesive tape holding the cover on.
      Ask FixBot
    1. Compaq Mini 110 Screen Replacement, Screen: step 16, image 1 of 3 Compaq Mini 110 Screen Replacement, Screen: step 16, image 2 of 3 Compaq Mini 110 Screen Replacement, Screen: step 16, image 3 of 3
      • Remove the 4 screws keeping the screen on the plastic assembly.
      Ask FixBot
    2. Compaq Mini 110 Screen Replacement: step 17, image 1 of 3 Compaq Mini 110 Screen Replacement: step 17, image 2 of 3 Compaq Mini 110 Screen Replacement: step 17, image 3 of 3
      • Take the screen off the metal connectors by unscrewing each side. Each side has 2 screws.
      • The last picture shows the metal connectors that attach it to the display assembly.
      Ask FixBot
    3. Compaq Mini 110 Screen Replacement: step 18, image 1 of 3 Compaq Mini 110 Screen Replacement: step 18, image 2 of 3 Compaq Mini 110 Screen Replacement: step 18, image 3 of 3
      • Detach the cable from the screen. It is connected under the foil flap.
      • The large wire on the back of the screen is for both the webcam and the microphone, as well as the screen.
      Ask FixBot
Author
with
alea
1,441 Reputation
14 Guides authored
Cal Poly, Team 22-2, Maness Fall 2010 Member of Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
6 Members
180 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 80
All Time: 12,282
