Up to 20% off select tools
Compaq Mini 110 Hard Drive Replacement
Views: 41K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
130
All Time:
40,556
Comments: 6
4 comments on steps, 2 guide comments.
Go to guide comments
Completed: 16
16 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Easy
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Compaq Mini 110 Hard Drive Replacement, Battery: step 1, image 1 of 2 Compaq Mini 110 Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
      Ask FixBot
    2. Compaq Mini 110 Hard Drive Replacement: step 2, image 1 of 3 Compaq Mini 110 Hard Drive Replacement: step 2, image 2 of 3 Compaq Mini 110 Hard Drive Replacement: step 2, image 3 of 3
      • Push both tabs inward simultaneously and slide the battery out.
      Ask FixBot
    1. Compaq Mini 110 Hard Drive Replacement, RAM: step 3, image 1 of 2 Compaq Mini 110 Hard Drive Replacement, RAM: step 3, image 2 of 2
      • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
      Ask FixBot
    2. Compaq Mini 110 Hard Drive Replacement: step 4, image 1 of 1
      • Push out the side tabs simultaneously and pull out the old RAM module.
      • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
      Ask FixBot
    1. Compaq Mini 110 Hard Drive Replacement, Keyboard: step 5, image 1 of 2 Compaq Mini 110 Hard Drive Replacement, Keyboard: step 5, image 2 of 2
      • Remove the rubber pads located on the corners of your Compaq Mini.
      • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
      Ask FixBot
    2. Compaq Mini 110 Hard Drive Replacement: step 6, image 1 of 2 Compaq Mini 110 Hard Drive Replacement: step 6, image 2 of 2
      • Unscrew all the corner screws. There are four total, one under each rubber pad.
      Ask FixBot
    3. Compaq Mini 110 Hard Drive Replacement: step 7, image 1 of 2 Compaq Mini 110 Hard Drive Replacement: step 7, image 2 of 2
      • Unscrew the screw for the bottom case located in the RAM compartment.
      Ask FixBot
    4. Compaq Mini 110 Hard Drive Replacement: step 8, image 1 of 2 Compaq Mini 110 Hard Drive Replacement: step 8, image 2 of 2
      • Remove the three screws in the silver tabs at the back of the keyboard.
      • These are located at the back of the base under the screen.
      • Lift the keyboard away from the laptop.
      Ask FixBot
    1. Compaq Mini 110 Hard Drive Replacement, Hard Drive: step 9, image 1 of 1
      • Remove the three screws holding the panel in place.
      Ask FixBot
    2. Compaq Mini 110 Hard Drive Replacement: step 10, image 1 of 2 Compaq Mini 110 Hard Drive Replacement: step 10, image 2 of 2
      • Pull up on the tab to remove the hard drive.
      Ask FixBot
16 other people completed this guide.
Author
with
alea
1,441 Reputation
14 Guides authored
Cal Poly, Team 22-2, Maness Fall 2010 Member of Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
6 Members
180 Guides authored
2 Guide Comments
still cannot remove back of my compacq mini. i have taken all screws out as told but back refuses to part.
madudman - Reply Share
still cannot remove back of my compact after removing all screws. are ther any more hidden clips ? mike
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 130
All Time: 40,556
