Compaq Evo N1000v Rear Fan Replacement
    1. Compaq Evo N1000v Rear Fan Replacement, Rear Fan: step 1, image 1 of 1
      • Carefully remove the screws located inside the red circles.
      Ask FixBot
    2. Compaq Evo N1000v Rear Fan Replacement: step 2, image 1 of 2 Compaq Evo N1000v Rear Fan Replacement: step 2, image 2 of 2
      • Next, you will need to push down the "F1" key with the spudger and push it under the silver LED display panel.
      • Push down on the spudger to lift the LED display upward.
      • Do this on both the left and right sides of the device as shown in the images.
      Ask FixBot
    3. Compaq Evo N1000v Rear Fan Replacement: step 3, image 1 of 1
      • Completely remove the LED display panel from the device.
      Ask FixBot
    4. Compaq Evo N1000v Rear Fan Replacement: step 4, image 1 of 1
      • Lift the keyboard up from the back end as shown in the image.
      Ask FixBot
    5. Compaq Evo N1000v Rear Fan Replacement: step 5, image 1 of 1
      • Pull the keyboard slightly toward the screen of the device to reveal the connecting cable below.
      Ask FixBot
    6. Compaq Evo N1000v Rear Fan Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Follow the cable to its connection and use the grip tweezers to unlock the cable by grabbing the left side of the lock and pulling upward.
      • Repeat this action on the right side of the lock.
      Ask FixBot
    7. Compaq Evo N1000v Rear Fan Replacement: step 7, image 1 of 1
      • Pull the keyboard upward to remove it from the device.
      Ask FixBot
    8. Compaq Evo N1000v Rear Fan Replacement: step 8, image 1 of 1
      • Unscrew the 3 screws as shown in the photo.
      Ask FixBot
    9. Compaq Evo N1000v Rear Fan Replacement: step 9, image 1 of 1
      • Remove the cable with the grip tweezers as shown in the photo.
      Ask FixBot
    10. Compaq Evo N1000v Rear Fan Replacement: step 10, image 1 of 1
      • Remove the rear fan.
      • Repeat these steps in reverse order to install the new rear fan.
      Ask FixBot
ryan
470 Reputation
2 Guides authored
1 Guide Comment
My Big Thanks! I cleaned the radiator, cooler greased and replaced the thermal grease from the CPU and GPU.
DeK-Test New - Reply Share
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 27
All Time: 844
