Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Tools
Spudger4.9
Introduction
Go to step 1 ↓Over time, the LED cover on the Compaq Evo N1000v may become cracked, loose, or discolored due to regular wear and tear. This repair is typically needed when the cover is visibly damaged or no longer holds in place, which can affect the appearance of the laptop and possibly interfere with the power or status indicators. This guide requires only basic tools and no advanced technical skills. While the repair is relatively straightforward, care must be taken when removing nearby components to avoid damage.
Before you begin this repair, power off and unplug your laptop.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
